Results 1 to 4 of 4
Thread: Buick series 1 to 2 changes, please help!
    Project VK
    May 2011
    Port Lincoln, SA
    Default Buick series 1 to 2 changes, please help!
    hey,
    Im currently rebuilding my VN series 1 V6 before i put it in my VK so far everything looks fine apart from the water pump harmonic balencer, timing cover and crank angle sensor, but today i picked up a VR motor for $50 that has got a snapped con rod i just wanted to know if the timing cover, harmonic balencer, crankangle sensor and water pump will fit my series 1 motor as i know there are a few different things for series 1 to 2. also what other updated parts do you think would be worth transfering over? any help would be great.
    pjdm1980's Avatar
    Feb 2009
    Geelong, Victoria
    The VR auto motors have a cam angle sensor so there will be a hole in the timing cover.
    Project VK
    May 2011
    Port Lincoln, SA
    Project VK
    May 2011
    Port Lincoln, SA
    Dont worry i found out from the guy at repco today that the timiing cover will fit just fine and to just leave the cam angle sensor inthe but unplugged, i am all so using the VR heads, intake manifold and trottle body.
  1. Series 2 Buick to Ecotec differences. Engine Conversion TORANA
    By LX_HATCH in forum V6 Development And Modification
    Last Post: 22-09-2010, 07:05 PM
  2. buick series 2 pistons and rods
    By l0stwhite in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 11-08-2010, 01:36 PM
  3. Buick series 2 to 1
    By ChrisR91 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 07-05-2010, 05:01 PM
  4. [WA] WTB: VR Buick engine of any series
    By VryNeat in forum Swap / Wanted to Buy / Trade
    Last Post: 18-04-2009, 10:58 PM
  5. Buick Series 1 and 2 inlet manifolds
    By 202injected in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 23-04-2008, 09:13 AM
