currently running 235's on my vn ss should be ok 4 the vt.
Has anyone tried to fit 245's on VT Series 2 SS rims on a VN? Or 245's on any 17" rims on a VN for that matter? Am also running super low's....![]()
Cheers.![]()
* RVN 355 *
Do they make 245's for a 17"? I was told by the owner of tyre place there are 235/45/17, then it goes to 255/40/17. I'm putting the 235's on the front & 255's on the rear with 8.5" rims all round on a VP with IRS. The VT SS rims should be 8's? so shouldn't be a problem for 245's if you can get them. I think anything bigger than 235's would rub on a VN though.
you put anything from a vt onwards onto a vn, you will need a adjustable panhard rod, thorows the body of centre, dont ask me how, but 3 tyre shops told me this
i am the god of britany spears womanizer on just dance on the wii
i have 235/45/17 on the back of my vq with irs and i cant get my little finger inbetween the tyre and the chassis. It might be different with non irs. but good luck getting anything wider on
245 doesnt fit on front hits the strut i found out the expensive way putting bigger wheels on the back stops u from roataing for even tyre wear stick to 235 all roun and save money in the long run 10 mm is no big deal in the overall look of the car
