Results 1 to 5 of 5
Thread: Water Pump Bolt
    '88 VN Sedan
    Jun 2011
    Default Water Pump Bolt
    Found my water pump was leaking this morning so ducked off & bought a new one. Removing the bolts from the old water pump though, the 3/8 bolt at the bottom centre of the pump snapped. I got the old pump off & found that the bolt actually snapped off about 3mm into the threaded hole. My problem now is can I go without this bolt (doubt it very much) & if not, how am I going to get the S.O.B. out of there so I can get a new one in? From what I know of them an EasyOut isn't going to work in this situation. Will I be able to drill out the old bolt & then run a new thread through there or is the cover too thin to allow that?
    Any help would be much appreciated.
    '88 VN Sedan, stock V6.
    VZ 2005 Executive Wagon
    Sep 2009
    Northern suburbs of Adelaide
    Actually from what you have described, an Easy out might just do the job, especially if you spray some penetrating fluid (WD40, etc) into the affected area and let it soak in for a while.
    Having said that, I'm not a massive fan of Easy outs. Apparently it is not unknown for them to break off themselves, leaving an even bigger problem.
    Sabbath''s Avatar
    Sabbath' is offline Take it out/Take it Back
    Turbo Diesel SR5 Hilux/VH 308
    Jul 2006
    Timing cover off.
    Quote Originally Posted by ari666 View Post
    i have a proper update for ya:
    sabbath is not fire proof.
    Quote Originally Posted by Reaper:
    cowl on your car is like having the most epic boob job ever and then fitting 4 grandma bras over the top
    Quote Originally Posted by Jecs:
    i dont know exactly what that means, but i feel like i should pull my pants down a lil
    '88 VN Sedan
    Jun 2011
    I'd really hoped to avoid pulling the timing cover off but if I have to that's what will happen. I'm going to put the old pump back on it tonight so I can nurse it up to a mates place on Saturday. He's got all the gear I could need so I'll tackle it there. I just hope I'll be able to run a new thread into the timing cover if I can't get the remaining bolt out with an easy out.
    Reaper's Avatar
    Reaper is offline Tells it like it is.
    E3 Senator Manual, VP SS
    Aug 2004
    Quote Originally Posted by MrNutter View Post
    Get a screw driver slightly smaller than the hole and try to wind it out. You will probably be surprised how easy it comes out. I've come across heaps and they all wound out quite easily.
    Reaper
    Reapers Black VP SS
    0-60 mph = 5.39 Sec, 2.30 60'
    Quote Originally Posted by skruba View Post
    practice makes perfect dude i was (still am) my bros guinea pig,he has been tattooing for near 2 years.
  1. VT Water Pump Bolt Leak
    By antheh in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 13-01-2011, 01:14 PM
  2. Need advice, how to remove broken water pump bolt thats rusted in
    By VSPantha in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 20-06-2010, 07:51 PM
  3. water disappearing - water pump - how to change?
    By vh-holden in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 28-07-2008, 01:30 AM
  4. Davis Craig Electric water pump 80litre pump
    By HIROLLA in forum Parts And Other Items For Sale
    Last Post: 16-07-2008, 10:31 PM
  5. water pump bolt snaped oh noo
    By badger__rox in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 01-04-2007, 06:07 PM
