Results 1 to 3 of 3
Thread: Auto sump plug
    VN SS
    May 2011
    New Zealand
    Default Auto sump plug
    Thought someone might be semi interested in this. I have no idea why there wasn't one in the first place, makes regular changes much easier than pulling a cooler line and pumping it out or pulling the whole pan.
    Couldn't get a new gasket anywhere here today and the old one was paper thin and split so went with gasket poo, didn't do the filter cause I might change that later when I know the trans has all the old fluid washed out plus my plug doesn't leak etc. Old fluid smelled burned, doesn't look fresh either. I'd say last couple owners passed over maintenance so they could afford pod filters and subwoofers instead.
    PS, the random weld in the one pic was me testing before I drilled the hole, didn't want to have a hole and no way to fix it. It had also been "repaired" with a pop rivet at some point as well.
    accentstencil's Avatar
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    I've considered doing this also, I can't understand why they don't have one just to make it easier, because it is almost impossible not to make a mess when removing the pan, especially without a hoist.
    MY RIDE
    Hangman's Avatar
    Hangman is offline Torana Addict
    2 commys, 3 Toranas and a WB Panel Van
    Jan 2010
    Newcastle, home of Toranafest
    Quote Originally Posted by accentstencil View Post
    Would make things a lot easier that's for sure. All 3 of my v6's are bout due for an auto service. I'm not looking forward to it.
    Quote Originally Posted by hakhawk View Post
    there are more pressing issues on the site, like choosing between vl's and potatos.
  1. vz sump plug
    By nuradh in forum General
    Last Post: 08-12-2009, 01:09 AM
  2. Sump plug - LS1
    By davway in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 05-02-2009, 04:57 PM
  3. sump plug
    By Loupy31 in forum VY Holden Commodore (2002 - 2004)
    Last Post: 22-02-2008, 01:17 PM
  4. sump plug
    By adamandtanya in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 14-09-2007, 02:33 PM
  5. sump plug
    By martinfitzy in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 06-09-2006, 07:22 PM
