Results 1 to 7 of 7
Thread: vn calais fuel gauge/temp gauge cluster voltage board
    1990 VN CALAIS 3.8 LITRE V6
    Jul 2011
    shepparton
    Question vn calais fuel gauge/temp gauge cluster voltage board
    hii all i have heard about the fuel gau and temp gauges failing/sticking and or not reading right or moving very slowly its a common prob
    alot of people have reslodered a voltage regulator board in the middle back of the cluster behind the tacho and speedo and it has worked.
    my fuel gauge died couple of days ago and then it woke up again and gave me F!@# all reading when i know i have plenty more fuel in the tank then it dies again.
    i wanted to know what do you solder on the voltage regulator board (which pins)
    has anione gots ani pics of one that could show please
    my fuel and temp gauges have been very slow and sticky for 1 year and bit now but i am really sick and tired of it i just want them to work properly as they should
    i dont wana end up on side of the highway outa fuel cos the f!@#$%^ gauge keeps reading wrong.
    can ani out there please help out a holden owner like ya selfs
    much much apreciated
    VP MANUAL S/C 3.8 UTE
    Nov 2006
    Country Vic
    88greenvn he is the man that can sort you out
    Quote Originally Posted by HoZy View Post
    Please insert your keys into your rectum an sell the car for scrap...
    Regards
    Mathew
    Ek wagon 0-60mph 6.19 20/4/07 G-Tech so there is no cheating 1/8th mile @ mph Unknown , estimated 1/4 mile Unknown
    vp calais, vn calais, vp berlina all 3.8 litre
    Aug 2008
    Pascoe Vale South, MEL
    if you click on the "solution to sticky gauges" thread its all there. i flowed extra solder on every point on the voltage reg board and that seemed to do the trick...but if your still having trouble pm 88greenvn...
    dont sweat the petty... pet the sweaty...
    88GreenVN's Avatar
    88 Green VN Wagon 389,000kms
    Jun 2006
    Deep South - VN Country
    http://forums.justcommodores.com.au/...-1-cracks.html
    Solder the other side of the pins shown to fix most problems wit hthe voltage regulators.
    and 3 Dangerous non ABS VN's
    Jul 2011
    shepparton
    i have soldered the pins and the gauges are still slow and sluggish so what do i look for next whats my next move please anione
    cheers
    Nov 2006
    Country Vic
    Could be the cluster itself might be dodgy, do you have another cluster you can put in there to test to make sure your tank sender and temp sensor are ok??? If you get real stuck and cant work it out I might be able to help you
    Regards
    Mathew
    Jul 2011
    shepparton
    i have the cluster i orginally replaced with the one i have now but i will swapp the voltage regualtor boards over cos the one in the original culster is all fked up so will try that and see if ani better will try to do during the week cos got tafe
    thanks cheers
  1. fuel gauge and temp???
    By tekkado in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 13-04-2011, 07:45 PM
  2. Possible to splice a voltage gauge to pre-existing voltage gauge in dash?
    By VLC86 in forum Electrical Wiring / Questions
    Last Post: 16-12-2010, 06:30 PM
  3. temp gauge an fuel gauge not working
    By nathan_867 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 13-03-2010, 10:55 PM
  4. Fuel and Temp gauge voltage regulator
    By Fred Pelosk in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 10-03-2006, 02:30 PM
  5. vr fuel&temp gauge
    By zimmy in forum Electrical Wiring / Questions
    Last Post: 26-04-2005, 04:09 PM
