Results 1 to 11 of 11
Like Tree1Likes
  • 1 Post By franklinfrog
Thread: Harmonic Balancer Removal :(
    VP Berlina
    Jun 2011
    Epping, Sydney
    Default Harmonic Balancer Removal :(
    My CAS sensor apparantly died on me a few days back. Had Lube Mobile come and attempt to remove the Harmonic Balancer; as I simply could not!
    Much to my surprise; neither could he. Breaker bar, starter motor method; and rattlegun method. The thing just won't budge.
    Oh poo.
    HSV Coupe V2 GTS
    Nov 2010
    Default ooh poo
    Try to lock the wheels in gear unless it's a auto then it's a bit harder but you should be able to crack it with the starter with a good crank !!!!
    Hangman's Avatar
    Hangman is offline Torana Addict
    2 commys, 3 Toranas and a WB Panel Van
    Jan 2010
    Newcastle, home of Toranafest
    Really? I've never had trouble undoing the bolt using a big arse breaker bar against the chassis rail and giving it a kick in the guts. That's the easy part.
    Quote Originally Posted by hakhawk View Post
    there are more pressing issues on the site, like choosing between vl's and potatos.
    vp calais, vn calais, vp berlina all 3.8 litre
    Aug 2008
    Pascoe Vale South, MEL
    theres a tool to lock the flywheel might make it easier while your wrenching on it... there a custom made one on this thread have a look
    Locking the engine on a VP auto
    dont sweat the petty... pet the sweaty...
    *uwishn* is offline Holden special vehicles
    vl walkinshaw(replica) vt clubsport r8
    Jul 2010
    sydney
    i have had this problem(heat the bolt a little should get it moving then you can buy pullers to remove the balancer,
    it has 3big claws repco should have them think i paid 40buks.
    My VL Walkinshaw replica project
    vr v8 calias
    Jul 2011
    victoria
    i had to change one in my vn a few yrs ago but i had trouble taking it off as well so i tried every method in the book as well but what i did was put a ratchit on the h b with a long bar put the bar at the opposite side of the way the engine turns then turn over a cranck or two should pop. good luck i was stuck on mine for 2 weekends till i did that.
    Vx SS Gen III
    Nov 2006
    Northen Subs Melbourne
    done Mine the other day Used a Breaker Bar at First she didnt wanna come loose cranked it fast clicks and she come off Then use a Super crap pulley But the bolts They Supply are To big you will need x3 8mm bolts with some length and screw them in you will no the rest !
    VP Berlina
    Jun 2011
    Epping, Sydney
    We cranked the starter with a breaker on the nut a decent 10 times. Still didn't want to move It's persistent. Well, now it's at the workshop getting fixed; I hope to see my little jewel back in the driveway real soon.
    VN Exec Wagon S2 340K
    Oct 2009
    Not to worry, no breaker bar, rattle gun or endless cranking would get mine off. Ended up heating it with an oxy until the bolt was red hot and the rubber was on fire, then splashing cold water on it. Numerous repetitions and some serious worry later, the rattle gun got it off. 15 Years of tightening certainly makes it hard. It'll come good.
    matty94's Avatar
    matty94 is offline Addicted 2 VN's
    Vn Berlina
    Apr 2011
    Dandenong area S.E VIC
    An oxy is the way to go had to do the same on my mates old vp.
    VN White Berlina Sedan V6 (S1) Full Lukey Exhaust Lovells Springs 15x7 Interceptors v8 Throttle Body Custom Tune Calais Grill Mulberry Calais Seats 2 12Inch Alpine S-Type Subs Level 3 Cluster.
    vn calais 3.8
    Apr 2011
    hey mate,
    if your in melb and get your car back from the machanics ill do it for ya all you gotta do is get a 50 dollar pulley from supercheap auto and let me do the rest, if you havent got the bolt off well we need a rachet and 2 rolls of electrical tape
    let me know by a pm
  1. Harmonic Balancer removal
    By AqaumarineVR in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 29-12-2010, 09:39 AM
  2. harmonic balancer removal
    By Rumbl in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 14-05-2009, 12:41 PM
  3. Harmonic Balancer removal?
    By VHSLX3300 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 22-01-2008, 10:22 PM
  4. Harmonic Balancer Removal
    By SSbeast in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 30-04-2007, 12:34 AM
  5. Harmonic Balancer Removal
    By andrew77 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 27-07-2005, 10:43 PM
