Results 1 to 17 of 17
Like Tree2Likes
  • 1 Post By 328FTW
  • 1 Post By 328FTW
Thread: Fogging up!
    1966 HR Holden, 1992 VP Commodore
    Jan 2011
    Gold Coast
    Default Fogging up!
    Hey fella's,
    Most cold mornings, my front windscreen fogs up on the out side? i cleaned it thoroughly cause i thought it might have just been dirty, but that hasn't help?
    Dont know if this could cause it, but the guy i bought the car off put a bypass hose for the heater tap, so theres no heater tap and the lines run from the block back into the block, and where the lines go back into the fly wall through those two connections, theres no hoses connected to them? could maybe air, or a moisture build-up cause it
    if anyones had this happen or has any tips, please let me know
    cheers!
    VN SS
    May 2011
    New Zealand
    Clean it thoroughly with some real evil windscreen cleaner that can remove even waterspots, maybe even a very fine claybar and apply rain-X. Rain-x is like....magic, I swear. Use it on helmet visors and all sorts.
    '94 VR Exec
    Feb 2010
    Wagga Wagga, NSW
    Try leaving the heater on but running the air-conditioning as well. It won't cool the air, just de-humidify it.
    1999 VT
    May 2011
    queensland
    you need to match the inside temperature with the outside temperature, so the colder the better
    '94 VR Exec
    Feb 2010
    Wagga Wagga, NSW
    But if there's no moisture in the air how can it fog up?
    SHEENY05 is offline Banned
    car
    Jun 2011
    somewhere
    Shoot TinSnips a pm and ask his advice.....detailing is his speciality and he is dam good at it
    calais24/7's Avatar
    calais24/7 is offline Mucca Mad Boys
    VS Calais II 5L, 98 rodeo v6
    Jul 2009
    Quote Originally Posted by 328FTW View Post
    what eveil windscreen cleaner do you use that gets rid of spots?
    VN SS
    May 2011
    New Zealand
    Quote Originally Posted by calais24/7 View Post
    Lots of things, I used to use glass science till I found that could leave scratches sometimes even if you followed instructions. So now I tend to use a soft cloth and a homemade polish normally used on perspex and gelcoat or if it's tough 0000 wool and the polish. It's hard work removing waterspots if they have been on a while.
    It's how I deal with the racecar that doesn't have A/C or a heater, just a bilge blower hooked into the old vents to circulate air and some rain-X anti fog on the inside and plain rain-X on the outside. Works a treat.
    vn calais 5.0
    Jun 2011
    victoria
    I have the same problem by the back window.. I use glass cleaner but have been told car polish works well but yet to try it..
    VX 'S' S1
    Apr 2005
    South East,Victoria
    an old remedy is to cut a potato in half then rub it on the inside of the windscreen then polish with a cloth .
    vp calais, vn calais, vp berlina all 3.8 litre
    Aug 2008
    Pascoe Vale South, MEL
    rain-x anti fog on inside glass, normal rain-x on exterior glass. end thread.....
    dont sweat the petty... pet the sweaty...
    Munz's Avatar
    Munz is offline Right Foot Action
    VZ Calais LS1 / VL RB30e daily
    Jan 2011
    Brisbane NTH
    Quote Originally Posted by 1BADHR View Post
    Hey fella's,
    park in a garage - problem solved
    As Long as there is moisture in the air your car is gonna get condensation on the windows
    1999 VT
    May 2011
    queensland
    Quote Originally Posted by F l a k View Post
    trust me it works, i drive early mornings everyday
    VP Berlina
    Jun 2011
    Epping, Sydney
  15. #15
    calais24/7's Avatar
    Jul 2009
    Quote Originally Posted by Munz View Post
    And if he doesnt have a garage?
  16. #16
    VP Berlina
    Jun 2011
    Epping, Sydney
    Condensation on windows, or anything for that matter is simply... Difference in A. Humidity, and B. Temperature; from inside object X to outside of object X.
    Unless you are God, or Chuck Norris... you may not conquer this equation.
  17. #17
    Jan 2011
    Gold Coast
    cheers for the advice guys
  1. SSV rear light - fogging up.
    By Luke V8 in forum VE Holden Commodore (2006 - ?)
    Last Post: 12-07-2011, 06:34 PM
  2. Bad condensation and fogging on inside of windscreen
    By ads18x in forum VE Holden Commodore (2006 - ?)
    Last Post: 15-06-2010, 12:28 PM
  3. Projector headlight fogging up...?
    By BANKS in forum General
    Last Post: 30-05-2009, 01:11 PM
  4. VE GTS Back tail lights fogging
    By ondie in forum VE Holden Commodore (2006 - ?)
    Last Post: 14-11-2008, 11:37 AM
  5. Windscreen fogging up
    By GMBanisher in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 08-10-2008, 08:59 AM
