hey guys, I'm currently having trouble finding the main vacuum hose on my 1990 VN SS, so i can finish up installing my gauge if anyone could send me in the right direction would be muchly appreciated.
Main vacuum? If you mean to the MAP sensor then it's mounted on the rear firewall on the passenger side and you can T into that line for a reading. Any feed behind the throttle body will do though, there are a couple capped off nipples near the throttle body that you could use which would work fine. Just pull the cap off and shove the correct size hose onto it.
