Results 1 to 3 of 3
Thread: VN Calais v8 running rough and making bad exhaust fumes.
    VG Ute ecotec/T5 5sp
    Apr 2011
    brisbane
    Default VN Calais v8 running rough and making bad exhaust fumes.
    hey guys, just wondering if u could shed some light on my problem. i have an 89 Vn calais which was originally a 6cyl auto, car was converted to a 5ltr B4 i got it. conversion was obviously never done properly coz car still has 6 cyl dash/engine bay harness, 60L tank and sender/pump. car intermittantly runs rough at traffic lights, also tacho/speedo and temp gauge dont work, and there has been a wire bridged between the plug on the ecu, and another small plug up under the dash, when i disconnect this wire engine will crank but not start????. any help is greatly appreciated thanks
    Apr 2011
    brisbane
    VP Ute
    Jan 2009
    Willowbank Qld
    Quote Originally Posted by ecotec_vg View Post
    I have done this conversion.This is level 3 dash yes?Tank and sender should not be a problem, what error codes is it throwing? Can you get a pic of plug that the wire goes to?
  1. Running rough as, running hot..Ideas?
    By Maxxiz in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 18-10-2010, 11:29 PM
  2. Vn - Rough start & Rough Running Below 2k
    By ghog1726 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 30-03-2009, 10:02 PM
  3. exhaust fumes in cabin
    By existentialist in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 19-11-2007, 10:05 AM
  4. Faulty ignition coil making engine run rough?
    By b3h3m07h in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 05-01-2007, 08:23 PM
  5. VR Engine light stays on running running alittle rough
    By AJKoo1 in forum General Discussion
    Last Post: 07-09-2006, 01:08 AM
