Results 1 to 12 of 12
Thread: Thermo Fans
    VP commodore
    Jul 2011
    South Australia
    Default Thermo Fans
    Hello, my stock VP has a Stock thermo fan that is not working, i have tried a hard wire and they DO power up and work, ive changed relays also no go, they wont come on when it reaches temp? Any one no if u get like a temp switch fault( if there is one )
    VP Berlina
    Jun 2011
    Epping, Sydney
    Quote Originally Posted by psychotic46 View Post
    Silly to make a new thread about this particular problem; as I posted up this exact problem not long ago.
    Nonetheless; my symptoms are identical to yours. Lets rub our noggins together and solve this problem!
    (Me thinks the culprit in my situation is the ECU. It was working fine before Mechanic X changed it.)
    Good luck OP! I hope you find a solution that works.
    89 vn calais v6
    Oct 2010
    i know the thermo fan comes on when you check for errors so see if it comes on then?
    vx s pack II
    Jan 2010
    aLKIDA
    Check coolant temp sensor
    Check for power & earth at the cooling fan relay socket.
    There should be a signal from the ECM telling it to turn on when the temp gets to a certain level.
    If this signal is missing then its the ecu. Check the coolant temp sensor first if this is faulty the fan wont turn on
    calais_cruzin's Avatar
    calais_cruzin is offline Calais_Rattling....
    92 VP Calais 3.8
    May 2006
    Gold Coast
    Im goin with ECU, got a mate with another VN/P to try his.
    I got a wreckers special ECU, wouldnt turn on the fan one hit the temp, turn car off n on n she worked.
    Went n got a refurb from Reppinco
    ________________________________________
    304runner's Avatar
    304runner is offline ( .Y. )
    VR 5.0 Ute & a 4runner with a VS SS trasplant
    Mar 2011
    Central Coast NSW
    VP commodore
    Jul 2011
    South Australia
    Quote Originally Posted by nghie View Post
    Oh i didnt realise sorry guys, im still new at search ill get it and stop anoying use soon lol, ok so i will try the ECU soon do i need a matched ECU or can it be calais,berlina ect i have just a boring as commy'dore! Also is the Idle speed control related coz now thats maken me stall all the time at the lights FML!!! if not ill just buy a new one
    VP Berlina
    Jun 2011
    Epping, Sydney
    If i'm not mistaken, I believe all of the VP v6's have the same ECU. The badging i.e. Berlina, Executive are just different "creature comfort" and exterior styling packs.
    Correct me, if I'm incorrect!
    vx s pack II
    Jan 2010
    aLKIDA
    I would check the coolant temp sensor before replacing the ECU. all you need is a mult-meter that can reads ohms.
    Check it against some specs.
    Then if coolant temp sensor checks out then move to the ecu.
    VP Berlina
    Jun 2011
    Epping, Sydney
    coolant temp would be a some place for op to start, but in my case, it was working one minute, car died due to crank sensor failure, ecu Had to be replaced because mechanic x shorted it out somehow and now there is no power running through the fuse box fan terminal.
    VP Exec
    Jun 2005
    There's a lot of info. useful to diagnosing cooling fan operation in the "How To" on switching VN-VP (and others) cooling fan manually by immortality, including temp. sensor specs.
    VP commodore
    Jul 2011
    South Australia
    ok sweet as ill have a look
  1. AU Thermo Fans
    By MY_84_VK in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 17-10-2010, 08:16 PM
  2. 304 AU or Ef thermo fans
    By v8_bomberdore in forum V8 Development and Modification
    Last Post: 03-08-2009, 07:08 AM
  3. Thermo fans
    By 12000 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 10-05-2007, 03:19 PM
  4. thermo fans
    Last Post: 16-04-2007, 09:37 PM
