Results 1 to 6 of 6
Thread: VN radiator hoses
    ice_cold17 is offline Ice Cold
    1991 VN Executive S2
    Jun 2011
    warrawong
    Default VN radiator hoses
    Just got a new sport temp guage and it came with a piece that apparently u cut a radiator hose in half and have the piece in between as the new sender unit,it says to put it in the top hose where coolant exits the engine,i have a S2 91 VN executive and ive been told that the exit hose is the lower one..which is right?
    calais_cruzin's Avatar
    calais_cruzin is offline Calais_Rattling....
    92 VP Calais 3.8
    May 2006
    Gold Coast
    When standing infront of the car, the water exits the motor from the top hose on left side of engine
    ________________________________________
    Jun 2011
    warrawong
    azzfox's Avatar
    azzfox is offline slideways
    VN SV3800 #012, N13
    Sep 2005
    Yarra Valley, VIC
    Both the same. The difference is on the "S1" the top hose ran to the back of the motor because it was originally mounted in an east-west configuration. The inlet manifold on the "S2" was then changed to suit. Generally the top hose will always exit the motor because heat rises.
    My (ex)Ride
    Quote Originally Posted by ari666 View Post
    LMAO!!! bracelets!!! and neck chains?!?!? they are as gay as aids.
    Quote Originally Posted by Not_An_Abba_Fan View Post
    Nice 4 year old thread dig dude....got a permit to mine that deep?
    VP Exec
    Jun 2005
    The problem with sensing the temp. in the cooling hose is that it only senses the temp. if the thermostat is open and coolant is flowing through into the radiator. Is there any reason not to use the standard sensor location with the new gauge and sensor, other than not wanting to disable the cluster gauge?
    It wouldn't take a lot of effort to drill and tap a new hole for the new sensor either. There's probably room adjacent to the existing sensor. Check for clearance to alternator and thermostat, centre punch, drill, tap. This would make it easier to remove the gauge and sensor and plug the hole for the new sensor so you can transfer the gauge to another car or sell it separately. Also, unmolested cars are easier to sell.
    Maybe this seems intimidating but worst case you destroy an inlet manifold and you'd have to be pretty incompetent to do that. If you're capable of installing the gauge, I'd say you're capable of installing the sensor in the manifold.
    Jun 2011
    warrawong
    i would do that for a better setup but the new sensor is designed as a join for the hose,like i physically have to cut the hose in half and attach both halves of the hose to either end of the sensor,and the coolant flows through the middle and sends a temp through a wire to the new guage,only problem about all this is finding a hole in the firewall to get the wires through from the dash side. apart from that this setup should be fine,coz if do ever sell the car then replacing the radiator hose would be easy
  1. Changing Radiator Hoses Due to Degredation.
    By Sean880 in forum VY Holden Commodore (2002 - 2004)
    Last Post: 06-04-2010, 08:11 PM
  2. Replacing radiator hoses
    By Ron41 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 05-11-2009, 05:44 AM
  3. Silicone Radiator hoses
    By BANKS in forum General
    Last Post: 06-11-2008, 10:33 PM
  4. what do u guys reckon a new radiator with hoses would do
    By plAythiNG in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 08-11-2006, 06:31 PM
  5. FS: Mackay Top & Bottom Radiator Hoses To Suit 5L V8
    By ChRiDDa in forum Parts And Other Items For Sale
    Last Post: 09-06-2006, 07:55 PM
