Results 1 to 10 of 10
Thread: 1.5mm plug gaps for 5L motor
    VP Executive 5L
    Mar 2011
    Default 1.5mm plug gaps for 5L motor
    I wanna play with some big plug gaps but instead of widening the plugs I already have I want to use some plugs that are already made with 1.5mm gaps. I was looking at the V6 ones and they looked the same as the V8 ones - is there any difference between them apart from the gaps?
    Getting enough punch for the big gaps is not an issue.
    vs commodore
    Oct 2009
    Tamworth NSW
    wraith's Avatar
    wraith is offline Hand over the dog bikkies
    '95 VR Series II
    Sep 2008
    Demonicaland
    VB SL/E
    Dec 2008
    VP Commodore SS 1992
    May 2011
    Auckland NZ
    my 5L had 1.5mm gaps and it didnt run well over 3500 RPM.. Ive done some experimenting and think 1.14mm runs well.. But would love to hear your results. Dont stuff round to much just open up the gaps and get it done.. It only takes about 10mins to get them out 10mins to gap them all and ten mins to put them all back in.
    VP Executive 5L
    Mar 2011
    Quote Originally Posted by wraith View Post
    Why would you want big plug gaps?
    Smoother idle and part throttle.
    Tiny to no improvement in economy.
    No worthwhile increase in power.
    VP Executive 5L
    Mar 2011
    Quote Originally Posted by VR38 View Post
    money to burn.
    I want to be the first ever person to waste money on a car.
    VP Executive 5L
    Mar 2011
    Quote Originally Posted by 92 VP SS View Post
    The stock ignition is pretty tragic IMHO. That's more than likely the reason for lousy results when you get up in revs.
    Currently I am using an 7 amp ICE module but I can mod it internally to anything I like.
    Over the years with other cars I have run gaps as big as 100 thou (2.5mm) but that is too big because under compression the spark runs down the side of the insulator instead of across the gap. 80 thou is not bad but I will settle for 60 thou (1.5mm) because of the ergonomically placed distributor and I don't want it flashing over and have to replace the dist cap or rotor.
    Big gaps with long duration sparks are great for a naturally aspirated engine.
    VS L67
    Sep 2007
    BrisVagus
    If you want a big gap, 2.7mm, you can get Brisk LGS, I use them on both our L67's and they work an absolute treat. At 15 PSI there is no spark blow out using the standard Holden DIS with the L67 coil packs.
    Downside they are a little more expensive than Iridium's.
    Brisk Racing :: LGS SPARK PLUG
    When you do things right, people won’t be sure you’ve done anything at all,,,,,,,,,
    353RWHP L67 VS S Pack 6 Speed
    Kalmaker Tuning Software N03 N04 N05 N06 N07 N08 W00 W10 W20 W21 W30 W31
    W40 W41 W45 W46 W50 W51 W55 W56 W81 W85 W86 W91 W95 W96
    May 2011
    Auckland NZ
    Quote Originally Posted by Circlotron View Post
    They sound like good results. They say a smooth engine is an efficient engine. I experimented a bit with plugs after finding the my VP SS had 1.5mm gapped plugs in it from when I bought it and found 1mm lost low down power, in the end I settled on 1.14 as being my sweet spot :-) Although I wouldnt mind trying 1.25, I currently have been trialing bosch super 4s but Ive yet to decide on there results I may have to go back to my NGKs at 1.14 to determine.
    I think its great when people like us go and trial things and post their results to save others time . Cheers man.
  1. Cam's and plug gaps.
    By soop in forum V8 Development and Modification
    Last Post: 09-03-2010, 05:57 PM
  2. Spark plug gaps VN v8 LPG?
    By GTP 85 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 11-11-2009, 06:00 PM
  3. plug gaps
    By VYMAD in forum VY Holden Commodore (2002 - 2004)
    Last Post: 19-07-2009, 12:00 AM
  4. spark plug gaps
    By harro_VR in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 07-11-2007, 05:23 PM
  5. LS1 spark plug gaps?
    By VTSSDUDE in forum LSx Development and Modification
    Last Post: 24-12-2005, 10:10 PM
