i am after the codes for the id tags for vn to know what my calais came with from the factory
pull up the passanger side carpet under there is a spec / build sheet with lots of info on it cheers.
The build sheet won't always be there.
Easiest way would be to post up the codes you want to know and someone will tell you what they are.
Is there really a build sheet under the carpet? Look on the I'd plates, wouldn't that give you the codes and then google em?
yep they have build/spec sheets 90% of them have it
Can someone show a pic of it? What's the tag behind the left head light?
i cant up load but vl vn vp vr vs vt vx vy have them more info and pics on internet just type in vn build sheets i think ss clubs got info thats were i found out.
Ah cool.. Thanks..
your calais should have one cheers travis![]()
heres mine, just blanked out the last 3 digits of my build number.... they can be found under the floor on passenger side carpet, also theres one glued to the roof under the headliner cardboard....
dont sweat the petty... pet the sweaty...
i dont have the sheet but here are some things from my tags if anyone can help please
trim 16i
paint 2b059
eng lb9
trans md8
axle gu4
gu4 308 ratio/ lb9 v8/ md8 auto
wat bout the trim and paint
dont know its ether grey brown burgandy or tan for the paint is there any reason for exact name theres unique cars and parts holden site paint codes .com
cheers big help
