Today coming home at night and I pulled into my street and flicked the hi beam on and I lost the lights but only had Parkers. Turn hi beam off and the normal light come back on.. Gunna see if it's a blown fuse or globes tomorrow.. Any ideas what's going on?
Could be a relay or fuse, im not sure if they run separate fuses for high and low or not but they should have separate relays, could be a dodgy switch also.
pull off the fuse cover in the engine bay, the high beam is a 30 amp standard blade fuse, start there...
dont sweat the petty... pet the sweaty...
Are your goodbye lights still working fine?
Sorry -.- Very lame I know
The normal lights are fine. When you pull the indicator lever back to flash someone the hi beam does not work with no lights on.. When you have lights on and do the same thing the lights stay on but no hi beam.. When the lights are on and you push the indicator lever forward the lights go out and just Parkers are on..
I would check the relays, and wires around the relays. I had a similar thing with my VN SS, driving along, low beam working fine, high beam also working. Got close to home, flicked down from high to low beam, and lost all lights... worked fine on high beam, but nothing on low. Checked the relays, and the wires were a litle fried, cleaned them up, fixed the connections and all good.
