Results 1 to 6 of 6
Thread: cone in v6 intake manifold, wats it for?
    VC station wagon 202 project car, VP v6 sedan
    Apr 2011
    palmerston north, newzealand
    Question cone in v6 intake manifold, wats it for?
    Hey guys, i was told buy a guy the other day to pull the plastic cone in my intake manifold out. but i want to know what it's for before i do it. dose it js act like a restricter plate or sumthing? any information i can get would be much appreciated thanks.
    VK SL 5spd
    Sep 2009
    Wagga Wagga
    ice_cold17 is offline Ice Cold
    1991 VN Executive S2
    Jun 2011
    warrawong
    Yeah its the bellmouth,i took mine out,basically holden put it there to suit the family of that time because the series 1 models were a bit too loud or chirpy at the wheels,that bellmouth basically sent the air more evenly to the cylinders and "tamed the beast" so to say...i didnt really notice much difference when i took mine out,its a bit more lumpy on idle if anything,and at times it spins slightly off the line but nothing to get excited about,some ppl will say that you gain like lots of HP and accelaration and all that coz it opens up the air intake more but thats all BS,try it out and see how it goes,every car is different,u may notice a difference or u may not hope this helped
    vn calais 5.0
    Jun 2011
    victoria
    azzfox's Avatar
    azzfox is offline slideways
    VN SV3800 #012, N13
    Sep 2005
    Yarra Valley, VIC
    Leans out the rear cylinders without it. I took mine out but put it back in. Noticed no difference apart from a lumpier idle. I recently pulled that motor down and the valves were evenly colored so I would say leave it in. I did play around with cutting it but after that I just got a new one from the wreckers lol
    My (ex)Ride
    Quote Originally Posted by ari666 View Post
    LMAO!!! bracelets!!! and neck chains?!?!? they are as gay as aids.
    Quote Originally Posted by Not_An_Abba_Fan View Post
    Nice 4 year old thread dig dude....got a permit to mine that deep?
    vamplestat is offline calais93
    VP Calais
    Feb 2008
    Australia
    leave it in, you will gain NO improvement from removing it apart from a more shitter idle and leaning the 2 rear cylinders... to quote from someone else on this forum
    " guys been there and done this. now I know it doesn't do anything. I've tried taking it out, cutting half away, putting it back in etc.
    from the throttle body into the plenum there is nothing restrictive. from that point forward the motor will make 160kw's tuned correctly.
    I've done it on a dyno, and now I have it from the horses mouth. Hilton Lategan (australian service manager consultant for holden) removing does nothing but produce a worse idle.
    the restrictive parts on the motor are the exhaust, and everything from the throttle body to the air cleaner.
    all have been done, do keep power figures down, noise down and fuel economy up.
    get rid of the black plastic induction pipe and get a metal one from rocket for about $90. get a pod filter, or to stay legal a panel filter (K&N) why buy paper filters. they flow less and only cost half as much as a k&n but you have to replace them yearly. and k&n you just clean.
    buy a bigger throttle body. because the vn to vr has a map sensor and not a maf sensor, you can do lots more things and the computer doesn't really get affected.
    put the bellmouth back in. it will help your car to run smoother, and idle better. taking it out does nothing. dyno proven (no difference)"
    i took mine out to see if there was a difference and apart from a crap idle it make no difference between all the rev ranges, felt sloppy off the line, i out it back in and it idles much smoother and has a much smoother acceleration compared to having it removed..... your best bet it to go with extractors, exhaust, chipped ECU and a CAI and panel filter preferably KN and maybe a 70mm ported n polished throttle body. but as for the belmouth forget it you will risk more damage to your engine in the long run
  1. intake manifold
    By peter p in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 04-04-2010, 04:07 PM
  2. C.O.M.E Intake Manifold.....
    By S2_VR_ in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 23-07-2009, 01:14 PM
  3. V6 intake manifold
    By VPCalais38 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 14-06-2008, 03:27 AM
  4. WTB:VN-VT 5L V8 intake manifold...
    By KRUPTD in forum Swap / Wanted to Buy / Trade
    Last Post: 18-02-2008, 11:37 AM
  5. Intake Manifold G vs. H/G
    By azkwazere in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 12-02-2008, 12:09 PM
