Results 1 to 4 of 4
Thread: 304 thermo info.
    vp 5.0 litre
    Jul 2011
    bargo
    Smile 304 thermo info.
    Hi there...Just new to the forum,Ive got an 80 series landcruiser that I have just put a 304 in which was from a vq statesman. And having some dramas with cooling. Ive just put a new landcruiser petrol radiator in and because of the position of the motor now I cant run with the clutch fan. So Twin thermos are the only option. Now the problem is how do I go about wiring them up? Because I dont think this set up is designed to run through the computer. But If I dont run them through the computer then the computer is going to sense the motor is running to cold and its going to run ritcher, hence using more fuel than it should be. And I know there are a few people that have done the thermo conversion. Would be very much appreciated if anyone could shed some light on this.
    5.0 litre 80
    Rusty's Avatar
    Rusty is offline ٩(-̮̮̃•̃)۶
    304 Ute, WRX Impreza
    Mar 2010
    Queensland
    Have you looked into davies craig switches? I am not a hundred percent sure it suits your needs as i have only just heard about them myself
    http://www.daviescraig.com.au/Images...(06-06-06).pdf
    vp 5.0 litre
    Jul 2011
    bargo
    Yeh but not sure about by passing the computer, I know there the go for older non injected 5.0 litres.
    VP Exec
    Jun 2005
    The ECM won't care how the eng. temp. is maintained just so long as it is. The Davies-Craig switch will work but I have had them leak between the rubber seal and radiator hose. They also measure the coolant temp. in the hose, not the engine.
    There is provision in the V8 memcal to switch a thermo fan relay but in the original application it is an auxiliary fan that is switched i.e. it is switched at too high a temp. to use to switch a main fan. The MemCal can be rewritten to lower this temp..
    You might be able to use the Jaycar/Silicon Chip voltage switch using thevoltage from the coolant temp. sensor to the ECM as the input. Wiring it in would be easy but I think that there will be a problem in that the CTS voltage has a step in it wrt to temp. vs voltage and the same voltage may be present at two different temperatures.
    Silicon Chip Online - Simple Voltage Switch For Car Sensors
    Universal Voltage Switch - Jaycar Electronics
  1. thermo fan on a 5L
    By stateo 304 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 22-11-2010, 11:25 PM
  2. Excellent Info on REbuild for L36 or L67 Great info...
    By vxcalais_01 in forum V6 Development And Modification
    Last Post: 22-05-2010, 12:26 PM
  3. Thermo fan or not....
    By jason75 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 04-04-2009, 02:01 PM
  4. thermo fan
    By hold-on in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 14-07-2005, 05:22 PM
  5. Vs Thermo Fan Info
    By DJ Majah in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 05-03-2004, 09:43 AM
