just took tranny out of vn to change front seal. it was leaking badly got it back in now a knocking noise! it pretty loud too, any ideas?
Did you torque all the bolts to speck?
yeah. the ones from torque conv to flex plate. followed instructions from a genuine manual iv'e got. was sure everything was good.
Might be silly question but is the seal not in backwards?
hope not! i think it can only go one way, but i will take off the little dust cover and check. doubt its the seal though bcause its not leaking trans oil.
Rear mount done up?
Illegitimi Non Carborundum
yeah rear mount done up but i will check again, knock seems to be in rear of engine.
you can use a short length of garden hose as a stethoscope. It's remarkably effective in working out where a noise is coming from. Good luck with the noise.
seems to run quiet when i start up then start to click after half a minute or so. sure the converter is right in the gears all work ok. got me puzzled got some time tomorrow i'll check all the mounts etc.
