Results 1 to 4 of 4
Thread: VS Steering Rack into VP
    VP Calais
    Aug 2011
    Default VS Steering Rack into VP
    Will A VS Calais Steering Rack fit a VP Calais?
    VP calais, VJ valiant, BG5 legacy
    Jan 2008
    New Plymouth, New Zealand
    Nope, overall length is about 4 inches too long. You might get away with changing the rack ends, or cutting the VS ones down, but it would be easier just to get a vp one
    Quote Originally Posted by QuickVRII95 View Post
    Elaborate, For All Of Us... How The Hell Is A Commodore A Friggin 4-Stroke...???
    Where Are You Getting Your Facts From...???
    You All ARE Wrong About A Commodore Being A 4 Stroke Engine... Or Any Car For A Matter Of Fact...
    A V6 CAN'T Run On ONLY 1 Cylinder... IT'S A 24 STROKE ENGINE... 4 CYCLES Per Cylinder... "Basically Three V-Twins Together
    pjdm1980's Avatar
    Feb 2009
    Geelong, Victoria
    +1 the VS has a different rack.
    Morton's Avatar
    Fairstar the Funship
    May 2006
    Your biggest issue will probably be with high pressure power steering line fitment.
    The 1972 HQ Kingswood
  1. Swap variable speed steering rack for regular rack?
    By _R_J_K_ in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 22-04-2010, 08:06 PM
  2. steering rack
    By to_easy in forum VL Holden Commodore (1986 - 1988)
    Last Post: 10-03-2009, 10:26 PM
  3. will a vp steering rack fit a vr
    By eaton v8 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 21-09-2008, 10:06 AM
  4. oil line from power steering to steering rack
    By onmy6 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 14-12-2007, 10:08 AM
  5. steering rack
    By ab56452001 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 23-01-2007, 04:03 PM
Tags for this Thread
