Results 1 to 4 of 4
Thread: VP Commodore Series II Sump Bolt
    VP Commodore S2
    May 2011
    Default VP Commodore Series II Sump Bolt
    Hi Guys,
    My sump bolt is leaking a little and the thread is a little worn near the head so it looks like I need a new bolt however I'm having trouble locating one the same size.
    With the thread its diameter is about 13.8mm, without the thread the core looks like about 11-11.5mm and has approx 1.5mm thread pitch. It fits a 19mm socket.
    Nothing at supercheap seems to fit either. Its either bigger at 14mm with a huge head or smaller at 12mm (with much smaller thread). Holden can get one but don't have any on hand so I cant check if my bolt is stock. I checked Repco etc with no luck.
    Anyone doing a oil change able to check theirs with some calipers? This way I can tell if mine is stock (and get holden to order one). Or atleast know if mines been replaced with something oversize.
    calais_cruzin's Avatar
    calais_cruzin is offline Calais_Rattling....
    92 VP Calais 3.8
    May 2006
    Gold Coast
    just go to a wrecker n get one thats not threaded, also get a brass washer from supasheet as they start to concave after few changes
    got a bursons round u? or global
    ________________________________________
    VP Commodore S2
    May 2011
    Well i finally found one....
    auto1 is the only place that had one and it seems like it was 14mm, 1.5mm pitch.
    Christ that was a pain...i dont know if mine was stock tho, as everyone seemed to think it should be 12mm.
    Yay the car has oil....
    pjdm1980's Avatar
    Feb 2009
    Geelong, Victoria
    Your lucky, a mate brought a VQ 5.0Ltr and the people before had stripped the thread so instead of a proper fix the just welded the sump bolt on, so his first oil change was a engine out job!!!! Lol
  1. Vp sump bolt
    By nathanhrv in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 13-05-2011, 08:30 PM
  2. Where is the sump bolt located on VZ?
    By Tontos in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 08-03-2010, 05:21 PM
  3. Sump bolt size
    By StockoVRWagz in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 03-05-2009, 03:16 AM
  4. I NEED HELP with sump plug/bolt thing
    By Denno in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 09-03-2009, 09:03 PM
  5. Sump bolt?
    Last Post: 08-03-2009, 05:46 PM
