Hi
dose anybody know I want to use a vr L2 dash in a Vn I changing the front and the green wiring board on the back The Vn had No tacho it was a L1 will the tacho from the l2 dash work with the wiring board from the VN
If you use the VN PCB and warning lamp cards in the lens it will work no problems. What I would do is make the holes in the VN cluster for the L2 gauges (7 holes) and scrape away the green or blue coating. Then fit the gauges to your cluster.
I've converted about 30 clusters from L1 to L2 and never had a problem.
and 3 Dangerous non ABS VN's
