Results 1 to 7 of 7
Thread: Vn help please
    JGlinatsis is offline Ratty
    Vr Executive 3.8 V6
    Apr 2009
    Default Vn help please
    I need to get the ball joint off the strut from the power steering rack so i can change the strut and the sway bar link set up what is the best way to gt it off with out ####ing the thread?
    vn
    Nov 2009
    noble park
    i take it your talking about the tierod end?
    2 hammers hold 1 on the side of the steering arm and hit the oppersite site of the arm, the shock should dislog the tapered fit. I usally use a small sledge and an engineers hammer. give it a good hit
    *uwishn* is offline Holden special vehicles
    vl walkinshaw(replica) vt clubsport r8
    Jul 2010
    sydney
    you can buy a pulling tool that is'int to dear.
    My VL Walkinshaw replica project
    vp calais, vn calais, vp berlina all 3.8 litre
    Aug 2008
    Pascoe Vale South, MEL
    Quote Originally Posted by the_boozer View Post
    didnt realize there was 2 threads on this.... pretty much any variation of 2 hammers smashing the hell out of the ball joint should dislodge it lol.... i just hit the joint with 2 hammers at the same time on either side and that does the trick.... yours should work too boozer but id be apprehensive about banging on something that im not replacing... but it should be fine as long as you dont get too rough with it....
    dont sweat the petty... pet the sweaty...
    Hangman's Avatar
    Hangman is offline Torana Addict
    2 commys, 3 Toranas and a WB Panel Van
    Jan 2010
    Newcastle, home of Toranafest
    I usually just give a liberal spray with wd40 or similar, leave it for a bit, then hit the steering arm with a FBH.
    That said, I haven't done it on a Commodore, but the principle is the same.
    Quote Originally Posted by hakhawk View Post
    there are more pressing issues on the site, like choosing between vl's and potatos.
    VY SS
    May 2011
    Auckland
    So much easier to buy a tool. Got mine for $20 at Repco, the mechpro ones are sweet. Set it up and turn the bolt with a socket and she pops open
    VN SS
    Jul 2011
    Newcastle
    The pulling tools work okay, I have had them fail on older cars, the bolt just chews into the body of the puller when you try and wind it in. Failing belting the crap out of it with a hammer, just warm it up a little with an oxy, or even a gas torch, and should come off with a bit of a whack.
