just wondering if someone could give me a guied on removing the craddle and diff
from memory there is only 4 bolts holding the whole assembly to the body, 2 at the diff in behind the bumper there and 2 big bolts at the front of the assembly, then you just have to unbolt all the brakes/shocks and undo the tailshaft, have the car on stands and leave the wheels on so when you drop it out you can just wheel the whole lot out
"A life lived in fear is a life half lived"
will this help?
dont sweat the petty... pet the sweaty...
thanks heaps for that exctaly what i wanted
Hope you have a big breaker bar for the two forward bolts on the cradle, and the four holding up the diff ^_^ They're usually in tiiiight with about a litre of loctite.
Also make sure you use a liberal amount of Loctite Stud Lock on everything you reassemble![]()
The 1972 HQ Kingswood
I've found the easiest way to get these diff's out is to cut a hole in the boot floor. Makes undoing the 17mm bolts sooooooooooooooo much easier
Originally Posted by Reaper:
Originally Posted by Jecs:
You can get a rattlegun between the floor and the top of the diff hey??![]()
Wouldn't it be even easier to just cut out the sections of floor that house the cradle brackets, shock absorbers and wishbone mounts, and just let the whole unit drop onto the driveway?No need to undo any bolts at all!!!
