Results 1 to 6 of 6
Thread: vp commy
    vn v8,vp calis,vn wagon
    Jun 2011
    elizabeth
    Default vp commy
    ok boys suggestions welcome.headlights come on tail lights come on.courtesy lights in side come on.no blinkers no dash lights oil etc will not start.will not even click over nothing except the lights.
    FXST01's Avatar
    FXST01 is offline The Grey Man
    VP V6 Auto Sedan
    Jun 2005
    El-Arish-Shamal-Sina-Egypt
    Have you checked the main fusible link in the engine bay? Should be near the relays in their own little plastic case. The 60A one.
    Illegitimi Non Carborundum
    Jun 2011
    elizabeth
    Morton's Avatar
    Fairstar the Funship
    May 2006
    Sounds like a problem somewhere in your Accessory or Ignition relay. Healights and courtesy lights will work with ignition off, but indicators will not.
    Here's a good test - do your hazard lights work? The hazard relay operates under ACC OFF.
    Does your radio work? That operates under ACC and IGN, where your indicators and dash diagnostic lights operate only under IGN, so that can cancel out a fault with the ACC relay.
    If you can narrow it down to IGN, then as the above poster said - check engine bay fuses, primary IGN fuse, (and possible relay?) and if that fails, check for faults with your ignition barrell.
    The 1972 HQ Kingswood
    Jun 2011
    elizabeth
    main fusable link new one in same prob.radio does not work.tried testlight on fuses under dash.battery fuses light up,ign fuses dont.hazzard light work.i did change tail lights im running out of ideas.any suggestions please.
    Morton's Avatar
    May 2006
    Hazard lights work, but indicators don't:
    I would suggest that this means the problem lies with your Ignition circuit.
    Did you try the test light on the ignition fuses while the key was turned to ignition?
    As I said before, try changing main ignition fuses and the ignition relay, sometimes a relay can die without warning. Try exchanging it for another similar looking relay in the engine bay.
  1. Looking to buy A VX Commy What should I look out for.
    By Vxceptional in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 22-01-2012, 09:06 PM
  2. [ACT] F/S VS S3 Commy Ute
    By slidewayz_monaro in forum Vehicles For Sale
    Last Post: 29-06-2009, 02:11 PM
  3. 19s on VS commy
    By petezor in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 10-03-2007, 12:01 PM
  4. vs commy
    By Nathan72 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 07-08-2006, 08:55 AM
  5. my red p commy wag
    By effairmont in forum VN - VP - VG - VQ
    Last Post: 08-06-2006, 10:54 PM
