Results 1 to 2 of 2
Thread: fuel system
    vp 5.0 litre
    Jul 2011
    bargo
    Default fuel system
    Hi there,
    Just want to ask what the go is with the fuel system...just put a 304 into a landcruiser and is running fine most of the time. Im running a hp in line fuel pump installed (new) for a 5.0 vp commodore.Now the problem is I can drive it all day and not have any trouble with it, then all of a sudden I hear the pump and fuel rail howling having a whinge (Im thinking its starving for fuel) then shits itself for 10 miniutes and wont start. Im thinking because the pump isnt gravity fed maybe the pump is sucking air and causing an air lock at the pump.I can probably install an in tank pump which Im hoping will fix the problem, Any thought would be appreciated, and some Idea on what kind of pressures the in tank pump needs to be would be great.
    5.0 litre 80
    Morton's Avatar
    Fairstar the Funship
    May 2006
    The thirsty old V8s used a low pressure in-tank primer pump, which in turn fed the external high pressure. They also ran a dampener in-line to prevent fuel pulsation, but that bit isn't critical.
    If you just get yourself a standard Commoore in-tank pump with the right sender you should be laughing
    The 1972 HQ Kingswood
  1. Fuel system help
    By Tutty121 in forum LSx Development and Modification
    Last Post: 06-07-2011, 10:36 AM
  2. ve ss fuel system
    By psivyv6 in forum Sticks's EFI parts
    Last Post: 29-03-2011, 02:02 PM
  3. LS1 fuel system
    By savage1987 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 24-05-2010, 09:56 AM
  4. vr ss fuel system upgrade
    By 304hp304 in forum V8 Development and Modification
    Last Post: 07-02-2010, 06:10 PM
  5. Fuel System...
    By Bitemylip in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 09-12-2008, 10:57 AM
