Results 1 to 6 of 6
Like Tree1Likes
  • 1 Post By Morton
Thread: Vn series 1 V6 running on 5 cylinders or less.
    88 VL Turbo SL and 86 VL SL
    May 2010
    VIC
    Angry Vn series 1 V6 running on 5 cylinders or less.
    Hey guys i need help i bought a car thats idling very rough and has no ballz even on full punt the bloke said the injectors arnt spraying hard enough but another bloke reckons its running 5 cylinders or less.
    How do i check how many cylinders its running and what could cause this ?
    Modifying a car is like a drug once you start you cannot stop
    Holdens if your not in one your behind one
    Morton's Avatar
    Fairstar the Funship
    May 2006
    1st always check that the spark leads are all running to the correct cylinders. Having a couple around the wrong way can lead to a car running like it's on 5.
    Buy yourself a second hand Gregories from eBay if you can, it'll have all the info you need.
    The best way to check for injector pulse is to unplug them one by one, and plug a wedge style parker globe in the socket. You can just use one from your own headlight assembly. Crank the car over, and see if the globe in the injector plug flashes. It should flash noticably. Do this with every injector.
    Second, check each spark lead for fire, by either clipping a test light over each lead, or unplugging them one by one from the spark plugs and jamming a screwdriver in the socket of each lead. Ensure the screwdriver is contacting the metal clip in there, and hold it close to the engine block. Upon cranking over, you should see a spark leap from the screwdriver onto the engine block. Do this for each lead.
    You may find one faulty injector plug (I've had them before), or a faulty coil pack (also common)
    The 1972 HQ Kingswood
    May 2010
    VIC
    cool thanks for that i will give all that a go.
    vp calais, vn calais, vp berlina all 3.8 litre
    Aug 2008
    Pascoe Vale South, MEL
    Quote Originally Posted by morton View Post
    buy yourself a second hand gregories from ebay if you can, it'll have all the info you need.
    the best way to check for injector pulse is to unplug them one by one, and plug a wedge style parker globe in the socket. You can just use one from your own headlight assembly. Crank the car over, and see if the globe in the injector plug flashes. It should flash noticably. Do this with every injector.
    You may find one faulty injector plug (i've had them before), or a faulty coil pack (also common)
    do it! .
    dont sweat the petty... pet the sweaty...
    VN Aero / Liberty RS Turbo / VL Turbo
    Nov 2009
    http://http://forums.justcommodores....coil-pack.html
    Ive got a Max Ellery repair manual 1988 vn vp 1993 covers V8 and V6 that I dont need can sell cheap
    Quote Originally Posted by M3ZZA View Post
    Aug 2008
    Quote Originally Posted by Mayhem05 View Post
    ive got that one too, does the job nicely....
  1. 202 running on 5 Cylinders
    By dags061 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 28-08-2010, 09:31 AM
  2. vs running on 4 cylinders
    By zx7rtas in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 30-03-2009, 05:59 AM
  3. VN S1 only running on 4 cylinders
    By norman in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 26-03-2009, 12:55 PM
  4. Running on 5 cylinders.
    By J_D in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 11-04-2007, 07:03 PM
  5. Not running all Cylinders
    By Haze in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 02-01-2007, 07:59 PM
