Results 1 to 6 of 6
Thread: a little problem :)
    VP Berlina
    Jun 2011
    Epping, Sydney
    Default a little problem :)
    hello there guys. First off, I'll start with the problem.. The thermo fan won't kick in when the engine reaches temperature. So I've hard wired it to ignition. My previous car was a gti swift. It was very primal and the electronics were basic.. So i wouldn't say i was very savvy with electrical systems in cars. Can somebody please post up a guide in lamens terms on what to check.. Where exactly to check, and what parts to replace if need be. So far, my research has pointed me in the direction of the fan relay, and thermo sensor. What and where are these? Thanks guys! Dan.
    Morton's Avatar
    Fairstar the Funship
    May 2006
    There is a sensor behind your alternator. It has a blue plug, and two pins. It is screwed into the intake manifold, and sits next to another sensor.
    This blue two-pin sensor is your Coolant Temp Sensor, which relays voltage to the ECU depending on the temp of water, and then the ECU decides when to turn on your fan using that information.
    The fan relay would literally be a square four-pin relay, in your relay/fuse box in the engine bay. SHOULD be labelled.
    The 1972 HQ Kingswood
    ice_cold17 is offline Ice Cold
    1991 VN Executive S2
    Jun 2011
    warrawong
    that fuse box is on the left side of the engine right above the battery,its usually covered by a black plastic cover,inside the cover will tell you which relay is which,just a matter of changing it with the correct one,make sure you get one suggested by manufacturer as the wrong one could throw the whole thing into the fritz,this happened with mine,my fan turned on but at the wrong times,it got way too hot b4 turning on,all because the previous owner decided to do all the work himself without checking anything,so make sure you get the right relay,sorry to drag on a bit there but its a pain in the ass if you screw it up,believe me good luck with it
    VP Berlina
    Jun 2011
    Epping, Sydney
    So basically, If I changed these two items (Which I will do even if they aren't broken just to be safe); and it still doesn't work, you'd narrow it down to something wrong with the ECU?
    Thanks for the tips though, very precise
    Dan.
    VP calais, VJ valiant, BG5 legacy
    Jan 2008
    New Plymouth, New Zealand
    I would be looking at your fan if these two things dont solve the problem. ECUs are pretty bullitproof items, they are not known for failing. Also, it would be pretty unlikely for only one output of it to fail.
    Quote Originally Posted by QuickVRII95 View Post
    Elaborate, For All Of Us... How The Hell Is A Commodore A Friggin 4-Stroke...???
    Where Are You Getting Your Facts From...???
    You All ARE Wrong About A Commodore Being A 4 Stroke Engine... Or Any Car For A Matter Of Fact...
    A V6 CAN'T Run On ONLY 1 Cylinder... IT'S A 24 STROKE ENGINE... 4 CYCLES Per Cylinder... "Basically Three V-Twins Together
    Jun 2011
    warrawong
    so the fan does turn on when wired to ignition? if so then the motor on the fan is fine,its just ur fuses or relays,if its not them then you probably have a short somewhere,also change your thermostat,it may not be opening at the right time therefor your fan may not be going because of that,it could also be a short somewhere in the circuit but that would be unlikely in this case,i wouldnt say its the ECU,if it is then you would have bigger probs than just a fan.
  1. [VR-VS] How To: Fix the VS V6 4 Wire O2 sensor earth problem – Known Holden Problem
    By ephect in forum Holden Commodore How-To's
    Last Post: 17-01-2012, 11:25 PM
  2. VK v8 breathing problem/oil pressure problem
    By Bookanun in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 07-12-2010, 03:02 PM
  3. idle problem, very difficult to find problem
    By calais s2 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 11-07-2010, 10:51 PM
  4. Central locking Sv6 problem. this going to be a problem car??
    By philsv6 in forum VE Holden Commodore (2006 - ?)
    Last Post: 21-04-2010, 10:40 AM
  5. Pt 2 cold starting problem - Is my ECU the problem??
    By manfred in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 10-05-2007, 09:56 PM
