Results 1 to 9 of 9
Thread: Running vp v6 timing
    v6vpute's Avatar
    v6vpute is offline Rolling on stockies
    1993 vp s sedan series 2
    Jun 2009
    Lakes entrance vic
    Default Running vp v6 timing
    hey guys and girls
    I am getting rid of the commy becasue me and my dad are starting a 29 dodge project and what were gunna do is use my commy as a doner. we want to run triple carbs on it just coz we want to lol. Any way for the engine we want to get rid of all the sensors except the timing for the spark plugs so if we just run the crank angle sensor and the coil pack plugged into the ecu and have fuel fed thru the carbs will the engine run?
    vr commo
    Aug 2011
    places
    no you need temp sensors knock sensors and all the rest the best idea i can think of is use a haltec then you can tune with the carbs the dfi on these engines likes all the sensors there if they arnt it will have no idea when to retard or advance
    you might even have to cut up a tb for the tps
    o2 sensors arnt important because the engine wont be able to control fuel input so the o2 sensors are probaly the only ones you would want to get rid of srry o2 sensor not sensors lol
    v6vpute's Avatar
    Jun 2009
    Lakes entrance vic
    Ok so i cant get rid of any other damn
    Why is the temp sensors needed all i want to do is make the spark plugs spark lol doesnt have to be the best performer
    pjdm1980's Avatar
    Feb 2009
    Geelong, Victoria
    If you want a carby V6 why not try a Chevy V6, much easier to set up?
    v6vpute's Avatar
    Jun 2009
    Lakes entrance vic
    Coz its a budget build to sell on to fund the completion of my dads close cab pick up and thought it would be cheap thing to do
    Morton's Avatar
    Fairstar the Funship
    May 2006
    It needs all the sensors because it uses all that information to calculate spark advance. I don't know the V6 computer as well as the V8 one, but I think it may retard the timing if it thinks anything is going wrong. Problem is, there's no dizzy to turn forward/back, so you're relying 100% on the computer for your spark map.
    The 1972 HQ Kingswood
    Morton's Avatar
    May 2006
    I think if you want to keep it non-dizzy, and you're looking at keeping the ecu, you'll need to keep all your sensors or get a controller for the DFI. Maybe you could get a Haltech system up and running? You may have to set it up on static timing on the stock delco - override the advance/retard etc. You'll lose power, but it'll be cheaper than getting a complete DFI controller from the USA which will allow full spark curve mapping.
    Alternatively, you could import one with a dizzy from the USA
    v6vpute's Avatar
    Jun 2009
    Lakes entrance vic
    v6vpute's Avatar
    Jun 2009
    Lakes entrance vic
    Ok talked with dad today about the motor gunna run 6 gutted single barrel holdens carbs and keep the fuel injection runn all sensore just hide the wiring gunna start on the manifold this week and go from there might start a thread in the project section will need help down the track
  1. question about timing and running 5 cylinder
    By harry1994 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 05-07-2011, 06:02 PM
  2. Timing belt to Timing gear's ?????
    By MMH84D in forum VL Holden Commodore (1986 - 1988)
    Last Post: 18-08-2009, 11:28 PM
  3. What base ignition timing are you running?
    By Slooth in forum Tuning
    Last Post: 31-07-2009, 05:44 PM
  4. HSV double-row timing chain vs timing gears
    By savage1987 in forum V8 Development and Modification
    Last Post: 05-10-2007, 12:04 AM
  5. VR Engine light stays on running running alittle rough
    By AJKoo1 in forum General Discussion
    Last Post: 07-09-2006, 01:08 AM
