Results 1 to 5 of 5
Thread: Water leak interior drivers side
    Vp V6 Sedan
    Jun 2011
    Rockingham WA
    Cool Water leak interior drivers side
    Help im racking my brains, own vp when it rains drivers side leaks. Ive tried have the hose trick,
    and cant seem to find where its leaking from. cleaned around the drain thingy near wiper motor
    seems to have helped but there still seems to be water getting in. any ideas of this would be great.
    VP Berlina
    Jun 2011
    Epping, Sydney
    where are you finding the water? I don't know if it helps, but i noticed on my own vp that there is a tiny bit of light shining through the bottom front corner of the front doors. Perhaps it's the same scenario with your car?
    Vp V6 Sedan
    Jun 2011
    Rockingham WA
    Im finding water drips down the drivers side kick panel,
    boot release lever then onto carpet and floor. Ive taken
    rain channel off the roof cleaned car and underside of the channel
    then replaced it, thinking water was running from highest point to lowest.
    Just starting to worry me as it seems to be leaking somewhere near the
    electrics, And i dont wanna fry my car as i need it for work and to get my kids
    around.
    VP Berlina
    Jun 2011
    Epping, Sydney
    to be honest, there isn't much you can do, besides either taking the Italian route, or the normal route. Italian route is to lift the rubber seals around the car and silicone underneath, or the normal route; replace the rubber seals altogether. If that doesn't fix it, you May have a rust hole somewhere. Check the wheel tubs near the mudflap area too. Look behind it. If you can. Dan.
    Xw GT replica/Vr s ute/Ef
    Jul 2011
    NSW
    door rubber could be the problem cheers travis.
  1. VZ Commodore water leak in boot- drivers side
    By Tezz in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 04-12-2010, 12:02 PM
  2. Water leak into drivers side of the cab
    By sparkydude3 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 10-02-2010, 05:03 PM
  3. coolant leak drivers side
    By articant in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 02-04-2008, 07:10 AM
  4. Drivers side boot leak.
    By _Mukas_ in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 09-06-2006, 08:41 AM
  5. Water Leak at Drivers Door
    By Naccas in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 26-08-2004, 01:34 PM
