Results 1 to 6 of 6
Thread: Whats the best
    1989 Vn Commodore Sedan
    Aug 2011
    south australia
    Default Whats the best
    hey guys can someone tell me whats the best transmission fluid for a vp commodore wagon
    its a TH700 automatic transmission.
    I want to be cautous and careful in whats best for the transmission.
    89 vn calais v6
    Oct 2010
    Aug 2011
    south australia
    Quote Originally Posted by ryan21 View Post
    castrol dextron 3, everyone says other stuff ruins it.
    cool thanks for that info, also would it be the same for the motor oil? or would it be differant
    89 vn calais v6
    Oct 2010
    pjdm1980's Avatar
    Feb 2009
    Geelong, Victoria
    Oils ain't oils!
    I think that a reasonable good quality oil (as long as your not talking K mart brand and the like) should be fine for a older style motor like the Buick/Ecotec's the key is to change the oil/filters regularly.
    Dec 2009
    For the transmission any fluid based on Dexron 3 or better specifications for example a Penrite or Nulon semi or full synthetic will also be OK. To be honest I had a VN and had mine serviced with a semi synthetic and I could not tell any difference. They may however have a longer service lif. I know the better quality Penrite fluids mention extended service interval.
    For the engine you can look up the various lube guides the oil manufacturers have up on the net. I used to use Magnatec 10W-40 in my VN and when I started using that it was a lot quieter especially the lifters.
  1. Whats this?
    By hN! in forum VY Holden Commodore (2002 - 2004)
    Last Post: 26-01-2011, 05:15 PM
  2. Whats this?
    By revhead33 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 01-10-2010, 07:37 PM
  3. whats this about?
    By VPplayer in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 24-04-2009, 01:12 AM
  4. Whats Next??
    By johnvtls1 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 22-10-2007, 10:39 AM
  5. whats the better oil
    By justbad4you in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 07-03-2006, 10:51 AM
