Results 1 to 7 of 7
Thread: How to take vn strut tops off
    JGlinatsis is offline Ratty
    Vr Executive 3.8 V6
    Apr 2009
    Default How to take vn strut tops off
    hey i need to take my strut top's off but never done it to a vn how do i get the bolt off with out the shock twisting when i cant get a socket and a flat head in at the same time??
    please help
    VT
    Apr 2005
    QLD
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    A rattle gun is the easiet way to do it. But you can use a pair of vice grips on the very top of the shaft as close to the top of the spring as you can. Wrap a piece of rag around the shaft as well so there is less chance of damage.
    Visit my Facebook page
    Vr Executive 3.8 V6
    Apr 2009
    i just reffed it off with a barker bar but now i need to tighten it back up and reafing aint cutting it so just the rag and vice grip will work?
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    Yep, rag and vice grips will do the job. When it is all back together and on the ground, give it a final tighten as the weight of the car will be on it and you can tighten it a bit more.
    azkwazere is offline Ahhh Yes, Ahhh Yes....
    VP 5-SPD / 24-SPD Racer Hybrid
    May 2005
    .....SE Burbs
    Offset open ring spanner and a flat head?
    Its easier to get it undone when the weight of the car is still on the shock... if you rattle it loose then you take the strut out then you can undo it easier.
    aZk.
    Wanted to buy:
    1. T5 V8 Bellhousing and Clutch fork assembly suit VP
    2. V8 Tail Shaft, T5, Suit IRS VP
    3. T5 VB Gear Box
    PM Me if you got what i need...
    Quote Originally Posted by ryno_vrx View Post
    honestly i doubt it will happen cause kanye west will just interrupt Armageddon anyways
    Morton's Avatar
    Fairstar the Funship
    May 2006
    1) Big ring spanner around the nut
    2) Big flathead in the top of the shock, and a long thin bar through the handle of the screwdriver for leverage.
    The 1972 HQ Kingswood
  1. strut tops
    By POVRTY in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 03-07-2009, 11:44 AM
  2. Strut tops
    By SweetWagon in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 19-05-2009, 02:36 PM
  3. [SA] wtd strut tops
    By vr-man in forum Swap / Wanted to Buy / Trade
    Last Post: 27-02-2009, 10:04 PM
  4. strut tops
    By skyper in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 13-02-2009, 01:50 AM
  5. Wtd Strut Tops Vk
    By Sik_Cordz in forum Parts And Other Items For Sale
    Last Post: 15-05-2008, 06:43 PM
Tags for this Thread
