hi everyone,
i have a vp with irs rear setup.
i just bought 18x7.5 inch rims with +40 offset.
will these fit ok with the irs rear end? or do i need spacers?
car is not lowered.
You response would be great
UZNPSI RX3 Sedan
Series 2 RX7
Series 4 RX2 Sedan
place them on and see what they look like
rims have no tyres...was hoping some could help me out without me pulling the wheels to check
Thanks
UZNPSI RX3 Sedan
Series 2 RX7
Series 4 RX2 Sedan
VP's generally need 35p offset when I was running my VT Clubsport wheels 17x8 235/45R17 and 48p offset, I used and 8mm spacer and there was no issue's with rubbing so 40p wheels should fit fine with 235 tyres
From what i got from a tyre place, the offset is that of the BWM wheels, so $$$ for the correct aftermarket wheel. If I am incorrect please someone tell me what can replace them. I run 235/35/R19 VY GTS and its not a good idea.
INNAWE (in awe)
Noun 1. awe - an overwhelming feeling of wonder or admiration; "he stared over the edge with a feeling of awe"
2. awe - a feeling of profound respect for someone or something; "the fear of God"; "the Chinese reverence for the dead"; "the French treat food with gentle reverence"; "his respect for the law bordered on veneration"
you'd need spacers on your GTS rims yeah? they'd rub on the inside of the gaurd.
BMW's run 35p offset or 28p I believe it's easier to walk into a tyre shop and ask for 35p wheels then BMW as they can be different in offset, stud pattern and tyre profile.
35P commodore wheels to suit VP. Thats all you need to know
ummm I may have them on ........ lol
INNAWE (in awe)
