Results 1 to 6 of 6
Thread: motor stall
    vr executive 3.8
    Feb 2009
    Default motor stall
    i have a vr powered by series 1 vn. engine has started to cut out on deceleration. starts again immediately. this is not consistent as it may do a couple of time a trip or go perfectly. no codes to report, only a no fault number. any one have an idea? thanx.
    vamplestat is offline calais93
    VP Calais
    Feb 2008
    Australia
    take out the series 1 vn engine for a start...... not a great idea haveing that setup, boys in blue will love you for it thou...
    easy fix thou, stage 1 rip out series 1
    stage 2 drop in ecotec...
    problem solved.
    vp calais, vn calais, vp berlina all 3.8 litre
    Aug 2008
    Pascoe Vale South, MEL
    insect and maybe clean out your throttle body of any deposits or muck... could be as simple as that...
    dont sweat the petty... pet the sweaty...
    vr executive 3.8
    Feb 2009
    ta good idea about the swap, but can't afford it on the pension. never got picked up by qld. trans when i registered it tho. i bought the engine years ago and put it in a vh but the body rusted away, so kept until i found another reasonable one a vr. the vh was the best swap ..went like hell and handled brilliantly, pity about the rust.
    WogBoyz's Avatar
    WogBoyz is offline Cammed & Eventualy Blown!
    08 VE SSV Ute
    Feb 2009
    Cairns, Qld
    I dunno but do the buicks have crank angle sensors? i know my mates starting doing that when his sensor was dieing on his ecotec
    Now Saving for a Harrop HTV2300 Supercharger kit!
    Quote Originally Posted by skyracer View Post
    On new years eve I got stopped by a pack of about 5 people forming a road block. All of them naked. They proceeded to turkey slap my car as I rolled past...
    VP Calais
    Feb 2008
    Australia
    they do have crank ange sensors. buicks ecotecs all share that lol.... however when the CAS starts playing up. it generaly stops the car from running when its at normal temp and the car wont start until the engine cools down, your best bet if your keeping that engine would be to check your injectors, could be a dicky one there, does it feel like its missfireing at all? could also suggest maybe fuel filter could be blocked? could be alot of different things
  1. hi stall
    By boothead in forum VL Holden Commodore (1986 - 1988)
    Last Post: 28-08-2008, 11:05 AM
  2. its about to stall??
    By h0Ld3n`VN in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 08-06-2008, 04:03 AM
  3. my VR wants to stall
    By daniel VR in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 26-12-2005, 08:30 PM
  4. stall
    By oshe in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 17-05-2005, 08:22 PM
  5. Air con= Stall?
    By scott8888 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 21-11-2004, 08:35 PM
