Results 1 to 24 of 24
Like Tree1Likes
  • 1 Post By nghie
Thread: having numarous shift points
    vn calais 5ltr
    Aug 2010
    Default having numarous shift points
    i am wondering if anyone knows if and how i would be able to have my shift light set to more than one setting at once for the different gears
    VP Berlina
    Jun 2011
    Epping, Sydney
    That wouldn't be something we could help you with.. Your answer lies more on the side of the manufacturer of your sick shift light. I'm sure you could get some fully sick shift light's that would have different settings for different gears.
    Super_Low 91's Avatar
    Super_Low 91 is offline ┌∩┐(◕_◕)┌∩┐
    Nimbus 2000
    Sep 2008
    Hogwarts
    If you need a light to tell you when to change gears then you should not be driving
    Signature Goes Here
    kcpwns's Avatar
    kcpwns is offline Kicker - Livin' Loud :)
    VY V6 Equipe
    Jan 2010
    Shepparton
    Quote Originally Posted by kevspec View Post
    Doesn't a shift light tell you to change at the set RPM?
    I don't understand why you would want to change that point in different gears? I dunno if shift lights let you do that...
    I'd just scratch the light and do the shift timing yourself.
    Quote Originally Posted by some_guy View Post
    This posts stupidity makes baby jesus cry.
    My Ride
    currently retrofitting projector headlights
    wraith's Avatar
    wraith is offline Hand over the dog bikkies
    '95 VR Series II
    Sep 2008
    Demonicaland
    vn calais 5ltr
    Aug 2010
    it is a auto goin to be doin quick times but the different gears will need to be shifted at different points for most efficent times. also if you guys are just retarts about the answers dont bother putting in your 2 cents
    Nimbus 2000
    Sep 2008
    Hogwarts
    I don get what you mean, the auto is designed to change at the most efficient point in the rev range, changing the shift points wont give you any noticeable gains. However if you get a shift kit to give you quicker an firmer gear changes then yes you mite get some gains because you wont be losing time during the gear changes.
    Signature Goes Here
    wraith's Avatar
    '95 VR Series II
    Sep 2008
    Demonicaland
    Superlow is right. If you want to shift it yourself get a manual.
    vn calais 5ltr
    Aug 2010
    man its is full shift kit and all the rest of the shit but anyway all im askin is can i get a shift light with different settings for each gear!
    SweetWagon's Avatar
    SweetWagon is offline booosted
    VS Berlina Wagon Supercharged & VU SS Ute
    Jan 2006
    Springwood NSW
    wraith's Avatar
    '95 VR Series II
    Sep 2008
    Demonicaland
    SweetWagon has it nailed. So you have a fully manualised auto huh?
    Nimbus 2000
    Sep 2008
    Hogwarts
    Even with a fully manualised auto, the motor is still only going to make optimal power at a certain point in the rev range, so having a shift light so you can change gears at a different point in the rev range is just pointless...
    Signature Goes Here
    vn calais 5ltr
    Aug 2010
    yous obviously havent had any drag experiance or racing to know that it is not always the fastest to shift at max power sometimes its better to shift early or later depending on alot of things
    wraith's Avatar
    '95 VR Series II
    Sep 2008
    Demonicaland
    Your driving on the street not dragging so what's your point?
  15. #15
    VP Berlina
    Jun 2011
    Epping, Sydney
    even i with basic mechanical and electrical knowledge know that the tacho is only linked to the revolutions of your engine. It has nothing at all to do with your gearbox and never will. Besides, as said previously the gearbox will change gears at the most appropriate time, whether it be 2500 or 5000. Unless you're an electrical expert as such, i emplore you to give up the idea, and scrap the whole idea. Shift lights belong in fully sick pulsar sss's. You are not Vin Diesel, you are not a guest star in the fast and the furious. You give commodore owners a bad name with your neons and spinners, and sick spraypainted interiors. End rant.
  16. #16
    pjdm1980's Avatar
    Feb 2009
    Geelong, Victoria
    I don't see the point in what your saying, but I have to say I used to love my monster tacho in my VH.
  17. #17
    AirStrike's Avatar
    AirStrike is offline Site Administrator
    2009 G6ET
    Jun 2003
    It is never better to shift outside of where the engine makes peak torque, if you feel the need to either the car is not setup correctly or you have no drag experience.
    To answer your question I don't know of a setup like you are asking for to suit a VN/VP. There are setups available but they require inforation from the ecu to know what gear you are in, the VN ecu does not have this information.
  18. #18
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    If you had any drag experience, you would know by the sound of your engine when to change gears. That and the seat of the pants feel. You can feel it when the torque peaks, listen to the engine, or if you really have to, watch the tacho and you will know when the torque drops off. Having the correct gearing for the engines torque range will keep the revs in the peak torque range when you shift. If you are building the car for "doin quick times", then you will be getting the gearing right as well so you are redlining in top gear when you hit the line.
    Visit my Facebook page
  19. #19
    Sabbath''s Avatar
    Sabbath' is offline Take it out/Take it Back
    Turbo Diesel SR5 Hilux/VH 308
    Jul 2006
    Then use your ears and the feel of the car? You dont need some awesome leb-spec shift light flashing at you to tell you to shift. And if you do, then you're a "retart" and shouldnt have had your car manualised.
    Quote Originally Posted by ari666 View Post
    i have a proper update for ya:
    sabbath is not fire proof.
    Quote Originally Posted by Reaper:
    cowl on your car is like having the most epic boob job ever and then fitting 4 grandma bras over the top
    Quote Originally Posted by Jecs:
    i dont know exactly what that means, but i feel like i should pull my pants down a lil
  20. #20
    vn calais 5ltr
    Aug 2010
    i never asked for all you dumb replys and if you knew anything a stage 3 is manualised and stage 2 is still an auto but to all of yous it is a street and strip car which is more than just a slammed piece of shit like im sure most of yous have and everything my car has is there for a reason
  21. #21
    vs commodore
    Oct 2009
    Tamworth NSW
    Quote Originally Posted by Sabbath' View Post
    I get them "retarts" from the cake shop here,geez theyre good ey.
  22. #22
    AirStrike's Avatar
    2009 G6ET
    Jun 2003
    I didn't know there was an Australian standards for gearbox 'stages'.
    I told you exactly what you needed.
  23. #23
    aaronevolution's Avatar
    aaronevolution is online now Donating Member
    TURISMO VZ SS 6.0
    Mar 2011
    Hastings, Victoria
    It may be 'manualised' auto but it's still an auto.
  24. #24
    kcpwns's Avatar
    VY V6 Equipe
    Jan 2010
    Shepparton
    So essentially he is asking about a shift light for an auto gear box?...rofl
    My Ride
  1. VT 5 Litre Auto shift points
    By Jim HX in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 09-12-2010, 11:09 AM
  2. Change Shift Points & Speedo In Auto
    By hq-racing in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 09-08-2010, 04:08 PM
  3. Replies: 2
    Last Post: 16-07-2010, 08:18 PM
  4. Will changing to 3.23 ,3.45 or 3.7 diff gears affect gearbox shift points ?
    By vsl67 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 11-05-2010, 06:05 PM
  5. LS1 shift points unpredictable after tune
    By Cursed CX8 in forum Tuning
    Last Post: 02-10-2009, 08:54 PM
