Results 1 to 6 of 6
Thread: '88 VN Calais - H/Beam Fuse melted
    VN Calais
    Aug 2011
    Default '88 VN Calais - H/Beam Fuse melted
    Hey guys I just bought a VN Calais, its only had a couple of things wrong with it which I've fixed up to get the car ready for Victorias tight assed roadworthies. But the High Beams don't work so I checked the fuse underneath the bonnet and its melted around the metal bits of the fuse. Do you guys know what causes this and the best way to fix it? I'm lost when it comes to electronics.
    VK SL 5spd
    Sep 2009
    Wagga Wagga
    A melted fuse is usually created by a bad earth, the high resistance in the circuit limits current flow makes the wires get really hot the same as having too much current flow/ amps being drawn through the wire, fuses are to protect high current flow (current flow is measured in amps) not high resistance.
    VN Calais
    Aug 2011
    Ah ok, when I bought the car the little earth wire that connects to the battery was disconnected, its been connected since I found it. Would that be what caused it?
    vr executive 3.8
    Feb 2009
    had this prob on mine, turned out to be a loose connection on the relay, wire going to fuse. clean and recrimp might save the day ..cheers.
    vn calais 5.0
    Jun 2011
    victoria
    Mine was the same.. The guy I bought it off was running 120 globes in it.. After you fix the prob get some emry paper to clean it up to make a good contact..
    VZ 2005 Executive Wagon
    Sep 2009
    Northern suburbs of Adelaide
    Quote Originally Posted by VK SL 3800 View Post
    Would you be kind enough to explain this statement a bit more in detail for me, as it has just blown my 30 years of electrical fitter experience out of the water. LOL
  1. melted fuse
    By macca69 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 21-10-2009, 06:44 PM
  2. Melted Fuse
    By Dezza in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 22-04-2008, 11:15 PM
  3. VK Fuse box melted
    By vknut in forum Electrical Wiring / Questions
    Last Post: 10-11-2007, 03:13 PM
  4. melted fuse box
    By VKnVLCalais in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 26-11-2005, 12:16 AM
  5. melted fuse
    By VNCommo in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 05-06-2005, 08:22 PM
