Results 1 to 2 of 2
Thread: [COLOR="#0000CD"]need help![/COLOR]]
    VN V6
    Aug 2011
    Default Need help!
    [SIZE=5]I'm having some trouble at the moment. My VN runs fine for a while then just dies whether on gas or petrol. Once I change the ECM unit and sometimes the chips as I have a power chip it generally starts straight away but then it starts dropping out again. It occasionally back fires which I'm guessing tuning but just seems weird that it runs well for a while then starts stalling. I don't know if it makes much of a difference but I tried to bridge the wires to get the codes but the engine lit up once and my fan is a thermo, so not sure I'm duing that right! The Engine light accasionally comes on. Just trying to work out if its just a tune up or if there would be problems with injectors, Any help on this would be appreciated
    VN S
    Oct 2006
    well it wouldn't be injectors if it's playing up on lpg too, has to be something that's common to both.
    I'd probably start checking ignition coz that's easiest to do. U'r plugs look ok? measure leads with ohm meter for 10-20k resistance? Corrosion on the DFI module pins that the coil packs sit on?(i've had that problem) the plug connector going into the DFI module seated ok? (give it a wiggle as that car's running)
    Good luck
  1. Replies: 1
    Last Post: 19-09-2010, 10:05 PM
  2. spring color
    By dmitch in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 13-12-2006, 03:52 PM
  3. color code
    By 3800_man in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 04-05-2006, 08:18 PM
  4. Vt color
    By bodge in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 15-07-2005, 09:56 PM
  5. My Vb... Ahh The Color..
    By Smooth_as_sandpaper in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 17-10-2003, 08:28 PM
