when acelerating in the vn i'm experiencing a shudder coming from rear end, i herd its common for vn's to do this would a new tailshaft fix this of sp hwat tailshaft would you guys recommend
I would check the centre bearing and uni joints. Cheaper to replace them than the whole tail shaft. Unless you use a second hand one from a car that doesn't shudder and see if it stops.
