Results 1 to 8 of 8
Thread: VP gearbox speedo sensor?
    1994 Hilux V6
    Sep 2010
    Newcastle
    Default VP gearbox speedo sensor?
    Hey guys, a mate has asked me to get a part for his berlina (unsure of year) as he lives near no parts
    Shops himself. Any way he has told me it's a gearbox speedo sensor or sender. He says it has to be that cause he replaced the speedo gauge and it's stil not working. I rang supercheap and they told me the gearbox doesn't have any sensors that they could find, the only speedo sensor is on the engine.
    Should I try a wrecker to see if they have a clue? Wat else could be stopping the speedo. I thought it ran off the back wheels
    VP Exec
    Jun 2005
    The sensor will be there, a little black cylinder that screws onto the back of the trans. with one white connector.
    Not the sensor? Wiring between the ECM, the sensor and the gauge.
    vp calais, vn calais, vp berlina all 3.8 litre
    Aug 2008
    Pascoe Vale South, MEL
    its at the back of the transmission and will have a plug hanging off it... where the drive shaft meets the extension housing seal (that area)...
    edit: yeah what he said...
    dont sweat the petty... pet the sweaty...
    VN S
    Oct 2006
    Hey i was under the car a weekend or two ago and happened to take a photo of mine. It's leaking oil, i think there must be an o-ring or something that's stuffed on it. So if u can see through the muck and grot and grease and piss that's it
    it's on the drivers side a far way back from the engine. Mine's a manual, dunn if that makes a difference
    vn calais 5.0
    Jun 2011
    victoria
    You will find a spedo sensor at the wreckers and about 20-30 bucks I think mine was a few months ago.. The auto 1 is on the left side and a little oil will come out but not much. They do have a oil seal a o ring., has 1 bolt that holds it in
    VP Exec
    Jun 2005
    Quote Originally Posted by defecat0r View Post
    Click image for larger version.
    Between the plate and the trans. extension housing is an 'O' ring (purple, if that makes a difference ). That gets real brittle with age and heat and no longer seals.
    It's an easy fix, just wash the oil and dirt off (to make the job pleasant and avoid getting crap in the trans.) and undo the sensor and the 10mm head bolt that holds the retaining plate. DIg the old 'O' ring out with a pick or scribe, clean the parts and fit the new 'O' ring. A bit of trans. oil on the ring helps it slide in.
    If that 'O' ring isn't leaking, there is a seal in the end of the sensor housing - VS19145, the only Holden part # I know .
    1992 VQII Statesman
    Sep 2008
    the o ring is $20 from holden, the speed transducer is around $400 new from holden
    1992 VQII Statesman
    1991 VP Calais/ 1992 VP Calais
    1992 VPII Vacationer Wagon
    VN S
    Oct 2006
    oh hey thanks boys, good info, i'll check it out
  1. [NSW] WTB: Speedo Sensor In T5
    By GunnaBeSumthingVP in forum Swap / Wanted to Buy / Trade
    Last Post: 15-11-2010, 06:47 AM
  2. Speedo sensor on T56
    By Wagon_Wheel in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 23-06-2010, 09:39 PM
  3. leaking speedo sensor transducer in a vp v6
    By zskinner in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 04-05-2010, 12:17 PM
  4. t5 speedo sensor help
    By thesanchez in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 30-12-2009, 08:50 PM
  5. speedo sensor wiring.
    By bendez in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 20-10-2008, 10:49 AM
