Hello, I recently picked up a grandpa spec VP Berlina, the electric antenna was not going down all the way and clicking at the end of it's cycle, I replaced it with a new antenna and mast, it goes up and down perfect now but still clicks 3 or 4 times at the end of it's cycle.
Any suggestions on what could be causing this?
Regards,
Chris
the travel on the motor is more than the length of the antenna wouldnt worry about it as mine has been doing it for 10 years
Where did you get the new mast.. Mine is bent![]()
Cool thanks.. Will have to get it when the pay goes in
ive mounted a hidden antenna under my dash, splice it into the 12v on the head unit and mount it at least 2 inches from metal and its good to go... been working for 3 years
dont sweat the petty... pet the sweaty...
its just the line (rope as its called) on the aftermarket mast that's a few teeth to long, you could just take it out and snip a few off or just live with it.
make sure the car is earthed properly. also with the adjuster switch on the cluster go all the way up before it clicks and all the way down before it clicks. after that should be okay
1992 VQII Statesman
1991 VP Calais/ 1992 VP Calais
1992 VPII Vacationer Wagon
About to put another power Ariel in my vn and what the easier way to put it in.. I know the inner plastic guard comes out and do I need to take the glove box out to get to the ariel cable?
Got the new 1 in and when you turn the radio on it goes up half way then back down again.. Also when you use the dash buttons to make it go up it goes up and a soon as you let go of the button it goes down.. How do I fix these probs?
