From what I understand they need to be earthed properly and use red coolant so they don't corrode.Jump on eBay they're about $170-
eBay Australia: Buy new & used fashion, electronics & home d
I have a Fenix aluminium radiator, no problems so far. As said above earth it properly and really flush your engine before fitting. Earthing the radiator protects against electrolysis. I am using Nulon long life coolant, it is green and the directions claim it is safe for all Holden Commodores and protects aluminium, brass, copper, solder, cast iron etc.
a standard triple core brass radiator is what you want. the alloy radiators and their quality is always questionable. lots of people who have them have had problems
1992 VQII Statesman
1991 VP Calais/ 1992 VP Calais
1992 VPII Vacationer Wagon
I thought that too until I finally ditched my leaking heap of shit Aussie desert cooler brass copper radiator and replaced it with a cheap $200 alloy radiator from ebay. No more leaks and it actually cools better. And if it can keep my 500+ Hp semi grout filled lump of cast iron cool then it should cool just about anything. China has picked up their act in production of things like this these days, the welders coming out of Asia are some of the best in ther world.
As long as you don't have any stray current then you shouldn't have a problem.
Cheap, fast, reliable.....you only get to choose two.
ive just put one in my vn v8 drag/burnout car paid $350 for it i didnt turn my car off for about 2 or 3 hours and when racing each burnout was hitting rev limiter and it didnt go over 80 deg c in burnout comp it did get hot but its a small pad with walls my temp went to almost 200 deg and it still doesnt leak i wont be going back to brass one. i used non premix green coolent Nulon long life coolant and it says it is safe in these radiators
my first car is a holden and i will die with a holden
http://i748.photobucket.com/albums/x...SDC10667-1.jpg
