Results 1 to 7 of 7
Thread: Overfilled the oil
    VP Executive 5L
    Mar 2011
    Default Overfilled the oil
    Had a *Milton the Monster moment the other day. The oil was down to the ADD mark so I put some more in but "Whoops! Too much!" Now it is about 15mm above the FULL mark. I did this often with a 202 motor, even as much as 20mm over the mark and never had problems. Will it be a prob with a 304 motor? I have driven it about 100km since and it seems fine.
    *For those too young to remember --> Milton the Monster Show - YouTube
    Pickle''s Avatar
    Pickle' is offline Donating Member
    VE Omega
    Apr 2009
    Sydney, NSW.
    Lol i did this in my VR, BLEW SMOKE ####ING EVERYWHERE. Like me mean couldnt see out the back windscreen it was insane. Yes it was my first time putting oil in the car and my brother was just like yeah add a little more..... Yeah as you'd know i went a little tooooooo far . Im not sure, but i'd guess if it seems ok it would be ok but someone will correct me for sure
    vn calais 5.0
    Jun 2011
    victoria
    i would drain it and refill. was it all new oil or just new to old to top up?
    WogBoyz's Avatar
    WogBoyz is offline Cammed & Eventualy Blown!
    08 VE SSV Ute
    Feb 2009
    Cairns, Qld
    Ive heard that overfilling the oil can blow seals/gaskets or something, personally id get under the car losen the sump plug til it just starts running and once u think enough has came out tighen it back up and check the level, or you could just drain the lot and put fresh oil and oil filter in
    Now Saving for a Harrop HTV2300 Supercharger kit!
    Quote Originally Posted by skyracer View Post
    On new years eve I got stopped by a pack of about 5 people forming a road block. All of them naked. They proceeded to turkey slap my car as I rolled past...
    VP calais, VJ valiant, BG5 legacy
    Jan 2008
    New Plymouth, New Zealand
    Put a clean container under it (in case you drain off too much) and undo the sump plug. Dont drop the sump plug in the container and dont do it while the engine is warm or hot or the oil will burn you and you wont be able to get the plug back in.
    Hold the plug over the hole to controll the flow, too.
    If you do end up draining it all out, just pour it back in the top. Dont worry about new oil and filter unless its due for it anyway
    Quote Originally Posted by QuickVRII95 View Post
    Elaborate, For All Of Us... How The Hell Is A Commodore A Friggin 4-Stroke...???
    Where Are You Getting Your Facts From...???
    You All ARE Wrong About A Commodore Being A 4 Stroke Engine... Or Any Car For A Matter Of Fact...
    A V6 CAN'T Run On ONLY 1 Cylinder... IT'S A 24 STROKE ENGINE... 4 CYCLES Per Cylinder... "Basically Three V-Twins Together
    wraith's Avatar
    wraith is online now Hand over the dog bikkies
    '95 VR Series II
    Sep 2008
    Demonicaland
    1.5 cm is bugger all. Doubt it will do anything that bad. I had mine like 3 or 4 cms over when it was leaking like no tomorrow.
    Morton's Avatar
    Fairstar the Funship
    May 2006
    Overfilled oil on the 304 can lead to frothing (wind off the crankshaft), and can lead to aerated oil being sucked up the pickup, and a loss of oil pressure.
    I would personally drain and refill for the 5 minutes it will take you, but it's your call
    The 1972 HQ Kingswood
  1. VR, VERY overfilled gearbox accidently.
    By mike49 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 05-12-2009, 10:55 PM
  2. Coolant system overfilled
    By Flat_White in forum General
    Last Post: 14-07-2008, 10:15 PM
  3. leak/overfilled trans
    By garfa in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 08-11-2005, 11:13 PM
