Results 1 to 3 of 3
Thread: vn calais v6 ping noise
    1990 VN CALAIS 3.8 LITRE V6
    Jul 2011
    shepparton
    Default vn calais v6 ping noise
    hi all
    when i drive ma calais round all warmed up when i put it into reverse it makes a ping noise like somethings hitting the tail/drive shaft.
    it also shunts into gear when i put it into drive is the transgoing or sumting wroing with tail/drive shaft not sure just wondering cause really dont like it when it does it.
    can anione shed sum light on the subject?
    thanks for ani ideas or inputs u can give me
    Morton's Avatar
    Fairstar the Funship
    May 2006
    Engaging your backward gear will put reverse torque loads on the engine, and lean the engine + exhaust system the opposite way. This can often lead to funny exhaust tapping/pinging/knocking noises in only reverse, if a part of your exhaust system is close to the chassis.
    The sudden gear drop into drive is an odd one... would really have to experience it to tell you. I suggest dropping into your local mechanic and getting them to have a listen to that one
    The 1972 HQ Kingswood
    Jul 2011
    shepparton
    when i put it gear generally it doesnt go in smoothly is that the way they are or is it not normal
    and maybe my uni joints are rooted on ma tailshaft for the reason for ping noise when shift in reverse
  1. ping or ticking niose
    By mobstaopm in forum VY Holden Commodore (2002 - 2004)
    Last Post: 08-11-2010, 08:37 PM
  2. Ping!!!
    By ch1mp in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 24-03-2010, 06:18 PM
  3. Ping and knock noise on start up VE manual 6.0 Litre?
    By mooks6669 in forum VE Holden Commodore (2006 - ?)
    Last Post: 09-08-2009, 09:36 PM
  4. Occasional ping from engine bay while driving
    By savage1987 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 27-09-2008, 09:22 PM
  5. black smoke, oil/coolant loss, ping when cold
    By kremprod in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 11-05-2006, 09:04 PM
