Results 1 to 6 of 6
Thread: changing extractors
    1988 Vn Executive
    Aug 2011
    ferntree gully
    Default changing extractors
    hey guys i'm wanting to change my extractors over and willing to give it a crack myself to save some coin is it possible for somebody to give me a step by step on what to do
    91 vn s
    Jun 2009
    Adelaide, SA
    off the top of my head.. please not that i am highly skilled at being not right.
    jack car up place on JACK STANDS ,, or car ramps do not get under car that is supported only by jack.
    ....google..........pacemaker extractors install guide vn...............ding!
    http://www.pacemaker.com.au/FittingI.../PH%205029.pdf
    before you begin dismantling everything, make sure that you have all the right tools, sockets, ratchet spanner is handy for the manifold-to-head bolts/nuts.
    and get a can of loctite 'freeze' anti-seize.
    and a beer.
    and peanuts.
    and a lounge chair.
    and maybe 4+ hours if this is the first time for you.
    goodluck
    Morton's Avatar
    Fairstar the Funship
    May 2006
    What type of extractors are you putting in there?
    Upload some pics, then we can tell you just how much of a pain it's going to be getting them in there ^_^
    Dropping the steering rack and starter motor is a big help; arguably necessary. It's also nice to have an extensive tool kit with a few different options for approaching various bolts.
    eg: 13mm spanner, 13mm offset spanner, 13mm ratchet spanner, 1/2" and 1/4" drive 13mm sockets
    Not essential, but really advisable because some bolts and nuts are just a downright pain for no good reason
    But all extractors are different lengths, so up some pics and I'll give you the rundown!
    The 1972 HQ Kingswood
    1988 Vn Executive
    Aug 2011
    ferntree gully
    that'll be sick i got them off a mate that didnt want them anymore so i'll ask him there a bit rusty o i was going to sand all the rust and re spray them doing that this weekend so i'll post up on weekend
    VP calais, VJ valiant, BG5 legacy
    Jan 2008
    New Plymouth, New Zealand
    Nah dont worry about sanding them and painting them mate, Even high temp paint will burn off after a week. If you have your heart set on coating them, get them HPC coated - but thats expensive.
    Extractors are a pretty easy swap over, the passengers side one should just slot straight in. The drivers one will need the steering rack dropped to get it in, which is pretty easy, just 2 19mm bolts and a bolt thru the intermediate shaft to the column. Make sure you do the steering rack bolts up tight again, even mark them with a paint pen after they are done if you are prone to leaving things loose.
    The rest should be pretty easy. You might need to re weld or heat and bend the rest of your exhaust if it doesnt match up perfectly. If it doesnt mate up flush (the y piece and the rest of your exhaust), dont try and pull it together with bolts or you will bend the flanges and they will always leak
    Quote Originally Posted by QuickVRII95 View Post
    Elaborate, For All Of Us... How The Hell Is A Commodore A Friggin 4-Stroke...???
    Where Are You Getting Your Facts From...???
    You All ARE Wrong About A Commodore Being A 4 Stroke Engine... Or Any Car For A Matter Of Fact...
    A V6 CAN'T Run On ONLY 1 Cylinder... IT'S A 24 STROKE ENGINE... 4 CYCLES Per Cylinder... "Basically Three V-Twins Together
    Morton's Avatar
    May 2006
    Quote Originally Posted by Andrew426 View Post
    Not true, VHT Flameproof paints will last for bloody years. I painted my V8 extractors in VHT Flameproof cast iron and after two years and 50,000km they were still mint, barring a few oil stains. All you have to do is heat cycle them properly as indicated on the can, and the paint lasts ages.
  1. [VIC] vn-vr turbo manifold - pacemaker comp extractors/3 inch exhuast/stock extractors
    By YILDI2 in forum Parts And Other Items For Sale
    Last Post: 25-08-2011, 01:40 PM
  2. [SA] 5L VN-VP extractors SWAP for VR/VS statesman extractors
    By DERTY in forum Swap / Wanted to Buy / Trade
    Last Post: 28-01-2011, 11:52 AM
  3. [SA] swap vl extractors for blue 202 extractors
    By leigh 7005 in forum Swap / Wanted to Buy / Trade
    Last Post: 01-06-2009, 09:34 PM
  4. changing extractors
    By greenvs in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 17-04-2008, 03:42 PM
