Results 1 to 4 of 4
Thread: Vn Auto
    VN Calais
    Aug 2011
    Taree
    Default Vn Auto
    I'v got a 1991 vn calais , am wanting to fit B&M shifter etc. Does anyone had this conversion done ? What is needed other than the shifter itself ? Is powerglide kit the way to go ? Auto is going behind injected 304 that has been stroked to 355.
    pjdm1980's Avatar
    Feb 2009
    Geelong, Victoria
    I think you'll find that Power Glides are more for drag racing and very high horse power engines, the B&M kits come with everything needed to I stall them.
    VN Calais
    Aug 2011
    Taree
    Tah mate, wasnt really shure which way ta go. So many different opinion's i guess.
    Morton's Avatar
    Fairstar the Funship
    May 2006
    A powerglide is a two speed transmission, traditionally bolted up to engines that have a tendancy to break everything else.
    A B&M Pro-Ratchet shifter is traditionally fitted up to manually-kitted automatic transmissions, and in the case of a stock TH700, is often used to break them
    The 1972 HQ Kingswood
  1. VE SV6 200 H0 Motor Auto 2008 Transmission Change of Auto oil
    By markholland in forum VE Holden Commodore (2006 - ?)
    Last Post: 31-01-2011, 05:24 PM
  2. Replies: 7
    Last Post: 21-07-2010, 10:45 PM
  3. difference between standard auto and turbo auto
    By Nackerz in forum VL Holden Commodore (1986 - 1988)
    Last Post: 27-11-2009, 08:56 PM
  4. Fuel Mileage Holden VZ Wagon(auto) Vs Subaru 2.5(auto)
    By phantomwalker in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 29-06-2008, 06:38 PM
