Results 1 to 4 of 4
Thread: 5 litre engine light
    Vn berlina Vn Calais Vn Exec
    Aug 2011
    Default 5 litre engine light
    Hi everyone I have a 89 vn 5 litre and the engine lamp keeps coming on I tested it and sure enough code 13 came up so I replaced the O2 sensor it was good for three days and sure enough it's keeps poping up every now and again and it's 13 i have disconnected the battery but no luck has anyone had the same problem??
    Morton's Avatar
    Fairstar the Funship
    May 2006
    A dodgy wire, perhaps? Is the plug for the O2 sensor nice and tight, with good contacts?
    Perhaps the car is running nice and rich, or you're doing MASSIVE bangers and glowing your exctractors like a boss 'till the oxy sensor dies?
    The 1972 HQ Kingswood
    Vn Berlina
    Jun 2009
    sa
    it could be the sensor is not getting a decent earth, as they earth through the manifold/ extractors. it was a common fix to fit an additional wire between the body of the o2 sensor and a good ground point. there is one just next to the alternator. they fixed this in later models by incorperating and earth return circuit in the wiring. these o2 sensors have 2 wires as opposed to the single wire ones im sure yours will have.
    vt 5.0
    Apr 2011
    adelaide
    i got a 5litre vt mine shows the same code its done it ever since i got high flow cats
  1. ENGINE light, ABS light, TRAC OFF light AIRBAG light and OIL light
    By jamierawr88 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 09-10-2011, 09:06 PM
  2. missing engine cover bolts 5 litre engine
    By justice4all3000 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 03-09-2011, 06:17 PM
  3. Replaced alternator in VP 5 litre but battery light still on
    By MasterOfReality in forum Electrical Wiring / Questions
    Last Post: 23-05-2010, 07:24 PM
  4. WTB: 5 Litre engine covers!
    By Blown V6 Hatch in forum Swap / Wanted to Buy / Trade
    Last Post: 24-12-2007, 05:32 PM
