Results 1 to 4 of 4
Thread: VP Fan wiring issue please help
    Vp V6 Sedan
    Jun 2011
    Rockingham WA
    Cool VP Fan wiring issue please help
    I have wired into my vp a set au thermo fans, my issue is now they wont run from the switch i installed.
    I wired them up to the old fan plug but also put in a switch that way i could turn them on earlier.
    It worked fine for ages now nothing, I replaced switch, fuse, relay. fans work fine. and now im stumped
    im thinking possible broken wire but unsure, any help on this would be great. Cheers in advance
    SweetWagon's Avatar
    SweetWagon is offline booosted
    VS Berlina Wagon Supercharged & VU SS Ute
    Jan 2006
    Springwood NSW
    Morton's Avatar
    Fairstar the Funship
    May 2006
    I suspect you've installed a switch to break the circuit that is only opened by the ecu anyway. You need to either hardwire the fans to a switchable relay, or tap a switch into the ecu thermo signal - blue with a white trace i think?? It's been a few years lol
    The 1972 HQ Kingswood
    Vp V6 Sedan
    Jun 2011
    Rockingham WA
    I have a switch withan led in it so i know fans are running, it has 3 prongs on base. 1) earth 2) Accesories 3) power.
    the two wires for accesories and power are hard wired to the fan relay
    in the fuse box behind the battery. and the rest of the wiring is standard. ive pluged the fans straight into the old fan plug,
    hope this helps, dont have a drawing at this stage but could do one.
  1. Wiring Issue
    By fozzy92 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 11-08-2011, 08:36 PM
  2. VS 4L60e wiring issue
    By pungent in forum Electrical Wiring / Questions
    Last Post: 21-09-2010, 11:56 PM
  3. vp wiring issue
    By godsey265 in forum Electrical Wiring / Questions
    Last Post: 15-03-2009, 01:24 PM
  4. help with a wiring issue PLEASE(grrrrrr)
    By Mountain in forum Car Audio
    Last Post: 24-09-2006, 10:26 PM
