Results 1 to 4 of 4
Thread: vn v6 fuel pressure issues
    vn commodore
    Jan 2011
    brisbane
    Default vn v6 fuel pressure issues
    hey guys i recently upgraded to a 1.5l surge tank with bosch 044, walbro internal lift pump, half inch lines,
    Now .... ive set the base fuel pressure at 36lb (which ive been told is right and what it should of been tuned at) and it runs like absolute dogs balls. however when i set the base fuel pressure at around 25lb it idles fine.
    im running a sard 1:1 rising reg. why would it be not likeing the standard base fuel pressure,
    it was tuned with the 044, sard reg, bosch green tops with std size fuel lines b4 i touched it.
    delcowizzid's Avatar
    в∞ѕтεכ √&
    Jul 2008
    NZ
    pressure should be 45-47ish psi with vacuam line unplugged and engine idling.but by rights there should of been no need to adjust the reg at all if all you did was install lines and surge tank
    vn commodore
    Jan 2011
    brisbane
    Quote Originally Posted by delcowizzid View Post
    ahh ok ill give that a crack. yeah we played with fuel reg adjustment when i put the pressure gauge on it :S adjusted it the opposite way than it should have been...
    в∞ѕтεכ √&
    Jul 2008
    NZ
    watch out for them cheap oil filled fuel pressure gauges they can read upto 15psi wrong
  1. High Fuel Pressure - Bad Fuel Economy?
    By Goldie87 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 03-10-2011, 11:23 AM
  2. blockage in fuel line - appears to be fuel pressure regulator??
    By ryan1980 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 30-08-2011, 06:23 PM
  3. 304 Oil pressure issues
    By stocky in forum V8 Development and Modification
    Last Post: 21-12-2009, 07:39 PM
  4. Fuel Pressure Regulator - Poor fuel consumtion
    By Chuckster in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 17-11-2008, 03:49 PM
  5. VN Oil Pressure Issues
    By milkandjuicecomein2litres in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 19-09-2008, 09:38 PM
