i wanna upgrade to l67 injectors for my supercharged application but cant afford a tune straight away. basically will the car run with the l67 injectors in? i know the v8 injectors run in the v6
V8 injectors are exactly the same that's why. Wait till you can afford a tune otherwise you will run into dramas.
They wont work, The L67 injectors fitted into the head on the supercharged engines, Not into the Vallie cover like the stock V6, but if you upgraded your injectors you dont need a tune because your engine would just lean off the mixtures so it is the same as the standard ones.
You need blue Magna injectorsBut they're not just going to give you more fuel unless the fuel map in your delco tells them to
The 1972 HQ Kingswood
oh ok looks like i need to get a custom memcal made up for them and to run my 10 psi pulley
