Results 1 to 5 of 5
Thread: clutch problems??? HELP.
    91 vn ss
    May 2011
    brisbane
    Default clutch problems??? HELP.
    hey guys.
    im having some problems with the clutch on my vn ss. it has a new clutch and cable and throw out bearing but when fully adjusted it still only has half a pedal. clutch was replaced before i got the car but not put back together so im not sure if there is anything missing or not.
    Morton's Avatar
    Fairstar the Funship
    May 2006
    As replied in your other thread, it sounds like your pivot ball is improperly adjusted for the new clutch. You always need to reset it when installing a newie, as all your dimensions are back to factory.
    You can find the proper height dimensions in any Gregories workshop manual. Unfortunately the only way to adjust it is with the transmission off.
    The 1972 HQ Kingswood
    91 vn ss
    May 2011
    brisbane
    VS SS 5L
    Oct 2008
    lol i have the opposite problem on both my t5's full pedal but the clutch only grabs riiiight up the top. Used some washers down by the clutch cable adjuster to tighten it up a bit...helped a little.
    HSV VP clubby 5.0lt 5spd
    Jan 2010
    waikerie, SA
    I had the same problem when I put my t5 in.. I turned up a sleeve to go where the cable fits into the gearbox, pushing the outer of the cable further away from the gearbox.. gave me more adjustment works fine now..
    mite be worth tryin that before pullin the box off lol.
  1. clutch problems
    By burnsy150 in forum General
    Last Post: 25-07-2009, 12:20 PM
  2. clutch problems
    By RufusŪ in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 22-03-2008, 09:11 AM
  3. clutch problems
    By naf33n in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 08-01-2007, 04:46 PM
  4. clutch problems !!!!
    By stevenwilson in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 22-08-2006, 05:30 PM
  5. Clutch problems
    Last Post: 23-05-2005, 09:29 AM
