Results 1 to 13 of 13
Thread: Speedo not working
    VP Berlina LX
    Oct 2005
    Default Speedo not working
    Hi,
    My speedo will work for a few minutes then the needle just drops to zero.
    When it goes off neither the speedo or odometer work
    Ive got a feeling its the speedo sensor in the transmission as the old whack the dash trick dosent work. I have another VN as well which does the same thing but you can whack the dash on that one and the speedo will work.
    Thats what makes me think it is the speedo sensor.
    Thanks
    s0sage's Avatar
    s0sage is offline Posting aimlessly ..
    MX6 - Turbo .... so flame me
    Mar 2005
    well why are you posting in here???
    go out and replace the speedo sensor mate!
    VN COMMODORE V6
    Oct 2005
    Johnsonville
    Exclamation
    Hi,
    I have a vn as well and my speedo, temp gauge did the same thing but the bash the dash trick worked. But in the end i just got a replacement speedo. It works fine but the temp gauge and petrol doing occasionly so i think you might be right but look at a new speedo dash board.
    Catch ya later
    VP Berlina LX
    Oct 2005
    sOsage,
    No need for a reply like that.
    Im asking for confirmation if it is that from someone that might have had the same problem.
    rattattack1313 Guest
    Cool
    Read around the forum a bit, mate..... try in here...bashing ur car to find new things .......................(I should really merge these threads...).....
    VN-88's Avatar
    VN-88 is offline fiery red vn manual
    vn v6 s1 manual
    Aug 2005
    victoria , lakes entrance, u live there tell me!!
    warney's Avatar
    warney is offline did you say bukakki party
    VL skid car what else are they built to do
    Mar 2005
    im in the same boat atm...
    replaced autop now speedo and kms dun owrk ...only very very intermittently!!!!
    would it have been the replacement of the auto or is speedo ###ked?
    VN-88's Avatar
    vn v6 s1 manual
    Aug 2005
    i think the speedo runs to the auto box, my mates on his blue bird was a cable or osmehting it it was just bolted on, he only did it hand tight and the speedo only some times worked... althought it was a bluey i think it would be similar, find were it hits the box and check its tight, or even attached
    vq~gangsta's Avatar
    vq~gangsta is offline Resident science geek
    VQ Statesman 5.0L
    Oct 2005
    where the speedo cable attaches to the front of your trans, unplug it from there, it should just be held in by one bolt and a little plate.
    When you unplug it, pull it out dead straight, and you'll have a little plastic cog sitting on the end of it. Check this cog for wear, if it looks like the teeth have been flattened out, replace it.
    In case you're speedo's out, it would also be a good opportunity to change the cog to one with more/less teeth to set the speedo right again.
    Forgive me if this doesn't work on the VN
    I've never tried this on mine, but i did it on my VB years ago.
    I'd rather push my Holden than drive a Ford
    VN COMMODORE V6
    Oct 2005
    Johnsonville
    Lightbulb
    Quote Originally Posted by warney
    My counter done exactly the same thing but when i replaced it, it worked fine so just havign a look at the connection in the dash cause it mite not be touching the computer part. Make shaw it is pushed in properly either side.
    Hope it helps!!!!
    vq~gangsta's Avatar
    VQ Statesman 5.0L
    Oct 2005
    Unhappy
    Quote Originally Posted by vq~gangsta
    Shit, the VN has an electronic speedo doesn't it, not mechanical.
    Oops, my bad
    VN COMMODORE V6
    Oct 2005
    Johnsonville
    Yeah its a electrical. But u can change it but wat ever is in the new dash u will have to put up wif how many k's they have done.
    VN-88's Avatar
    vn v6 s1 manual
    Aug 2005
    i replaced my dash cause it was playing up , although i just bought another 3 aguge one but it had 300thousand k's on it and my car has only done 180 so i just swaped the speed ounit over... cause it may not be the unit playing up it may just be connections... also although illegal my mate relised u can wind the k's back... he sorta explained it, its really easy apparently, so just wind back to ur old k's
  1. speedo not working
    By clyde in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 16-10-2007, 11:07 PM
  2. speedo not working
    By winton in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 02-09-2007, 10:47 PM
  3. speedo not working
    By MiSs MeOw in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 24-03-2007, 01:17 PM
  4. Working out speedo corrections....
    By NORTI in forum General
    Last Post: 26-02-2007, 10:22 AM
  5. km on speedo not working
    By frankyj54 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 02-07-2006, 01:01 PM
