Results 1 to 8 of 8
Thread: Steering rack and pinion
    VS STATESMAN 3.8L 1996
    Aug 2011
    Albany,West Aust
    Question Steering rack and pinion
    First up i need help, i have issues with rack and pinion and i cant find a vn at the wreckers in town and not willing to hunt for vn so can i fit any other rack and pinion from later or early model commys.
    WH II Statesman GEN III
    Jun 2005
    Dusty Dubbo
    do a search of vn steering rack's and find the part number you need, then cross reference this part number with other models. I would imagine any VN VP VR or VS would be very similar, but I'd do the part number search as some vehicles had Variatronic steering racks.
    I have a WH II statesman, and need a new rack also, I was assuming any VT or VX rack would fit, but apparently certain VIN numbered vehicles have different threads on the racks, so for me to find a second hand unit I have to find a VX S2 with a certain VIN number or higher.
    just do some research of what will fit your car, and you will be able to widen your search slightly
    Morton's Avatar
    Fairstar the Funship
    May 2006
    The VN has a different spline pinion to VP VR.
    The 1972 HQ Kingswood
    vs commodore
    Oct 2009
    Tamworth NSW
    I just bought a reconditioned rack for my VS off ebay,(the normal or non variable type rack). It cost $220 and $25 delivery, and I didnt even have to leave a $150 deposit for the exchange, or have to send them back my old rack like a lot of places that sell this type of stuff want you to do. This rack also came fitted with new rack ends and new corrugated rubber boots fitted, so theres no having to fit the boots or the rack ends etc, which saves a bit of mucking around, just bolt it straight up pretty much. It took me around 1 hour to do, but I also had to undo the drivers side extractor so I had enough room to remove the old rack.
    Id recommend looking at ebay for a reco rack, and I reckon around the $200-$250 mark isnt too bad a price for a recoed one. My car steers and feels way better now too since Ive fitted the new rack and had a wheel alignment done, and Ive noticed that theres no more knocking sound, which you could just hear when the steering wheel was turned slighty from side to side without the car running, I reckon this noise was probably caused by wear which caused a slight movement or excessive play between the rack and the pinnion.
    Jun 2005
    Dusty Dubbo
    definately the way to go, if you do get one from a wrecker, you'll probably find it won't be long until it needs replacing, especially being a VN as they are around the 20 year old mark now. I think if you look for a Reconditioned unit they are cheaper and you don't need to exchange your rack. while the remanufactured racks are more expensive and you need to leave a deposit and send your rack as an exchange.. reconditioned would be around $200 - $300 while the remanufactured racks would probably be around the $300 - $400 including exchange.
    Jun 2005
    Dusty Dubbo
    Aug 2011
    Albany,West Aust
    Cheers!, i will just cross ref. and go from there was hoping to get one soon.
    92 VP Calais
    Feb 2011
    brisbane
    Found out the steering rack on my VP Calais has a leak.
    Was quoted $480 for a fully recoed one, boots n all, fitted. (has the speed sensor)
    Bought a bottle of Lucas brand 'Rack and Pinion Stop Leak' for $13.85, which they advertise as having a
    "Money Back Guarantee", and guess what...? No more leak, it works!!!
    Saved meself a heap of dollars and hasn't leaked one drop since!
    Is probly only a temporary fix, but it'll do me, for now.
  1. rack and pinion
    By hN! in forum VL Holden Commodore (1986 - 1988)
    Last Post: 09-03-2012, 06:14 PM
  2. Commodore - Fitting VR struts, brakes rack & pinion plus steering colum to my VN...
    By bobmat111 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 21-05-2010, 08:04 AM
  3. [VIC] WTB - VR 5Lt Stato P/S rack and pinion
    By _Mukas_ in forum Swap / Wanted to Buy / Trade
    Last Post: 23-04-2009, 11:40 AM
  4. Rack and pinion
    By wondering in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 16-12-2007, 11:14 PM
  5. rebuild rack and pinion DIY?
    By friedchicken in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 24-09-2007, 10:02 PM
Tags for this Thread
